Home > Maintenance & Modifications > Rear end sitting low?
dhopable
United Kingdom 2007 Defender 90 Puma 2.4 HT Tonga Green
Hi -
I noticed the other week that my Puma 90 looked like it was sitting a little low at the back.
Ive mentioned it to a couple of people and they agree but dont know what it could be. Shocked
It drives fine, no knocks or anything but on the way home tonight i noticed that my dip beam headlights are quite high, which i dont remember them being. It looks like its got an invisible trailer behind it.
Could anyone tell me why it is and what i need to check/do to get it back level again?!? Embarassed
I am abit worried that it is the springs or dampers or something expensive Big Cry but i cant figure out how both sides would give out at the same time?
Please help me!! Shocked
Doug
Post #200078 8th Jan 2013 9:09pm
bob neville
Can't give you an answer I'm afraid Doug but maybe put your mind at rest ?
My TD5 90 has a similar stance. It has a heavy winch and bumper on the front. New shocks (Koni's) but still on it's 11 year old original springs.
A lot of people think it has had a lift but it is standard.
If you take the spare wheel off the back door does it level out ?
2013 Defender 90 CSW - sold
Post #200088 8th Jan 2013 9:28pm
dhopable
You know what i bet it would! Ive only noticed the lower end since changing the tyres a few weeks ago.
I had to space the spare with a couple of washers so the tyre didnt foul the wiper too. I bet that hasnt helped either.. Sad
If that is the reason what can i do?
Post #200091 8th Jan 2013 9:32pm
Retroanaconda
Mine is much the same:
Though this is due to my swapping about of the springs to get a nicer ride. The springs on the back are the original front springs. There's only about 2" between bumpstop and axle and it bottoms out on bumps sometimes. My plan (as I'm too cheap to buy new springs) is to knock up some 1-1/2" spacer blocks to go between the axle bracket and the spring seat. If that doesn't work then I'll get a new set of 90 front springs and try that in the hope that the current ones (at 21 years old) are just a bit sagged. Last resort, put 90 rears back on Sad
Post #200102 8th Jan 2013 9:40pm
bob neville
Looking at the picture I would guess you are on 265 or 285's ?
They are significantly heavier than standard 235's.
My spare wheel lives in the back now, have a look in my gallery (TD5) and you will see the cage arrangement I have fitted. The wheel lives under that as far forward as I can get it.
Other option is heavier rear springs, genuine LR are not expensive. However they may make the ride choppier.
Post #200103 8th Jan 2013 9:40pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
I thought mine looked low at the back last year so I replaced the springs and shocks (all new standard LR) and it looks exactly the same as it did, so I wouldn't worry about it. I also think it makes a big difference if you've go a full tank of fuel as that hangs behind the rear axel.
Post #200108 8th Jan 2013 9:57pm
dhopable
Ok cool glad to hear it.. Ive been wondering about it for a while and just wanted to make sure it wasnt anything serious..
Thanks for the help once again guys Thumbs Up
Doug
Post #200112 8th Jan 2013 10:10pm
Glynparry25
^^As pointed out, it is common thing with 90s. All the old army ones were the same too- I personally never liked that look- good job I have a 110 Very Happy
Glyn Dog Sheep
Post #200194 9th Jan 2013 9:31am
mikeh501
if you did want to change the stance then you shouldnt worry about the cost either. a decent set of rear springs is around £100 and the fitting takes about 30 mins.
Post #200197 9th Jan 2013 9:45am
ibexman
Some discovery spring isolators will give you 15mm back cheap option
Post #200225 9th Jan 2013 11:36am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Looks fine to me are the tyres bigger than standard remember the front wheel arches sit higher on the body work and the rear arches sit lower Thumbs Up 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #200634 10th Jan 2013 9:13pm
Cracka
2012 Defender 90 Puma 2.2 HT Fuji White
I have a MY12 Puma 90. I have 235/85Wrangler MTR's on it, it has covered 10000kms so I assume it has 'settled'. My ground to flare measurements are front 780 mm, rear 785 mm this is with the spare fitted on the back door, if I take it off, the rear raises 5 mm. Theses measurements are with tyre pressures at 32psi front and rear. I dare say your rears may have sagged Shocked
Hope this helps.
Mick
Edit....I just realized I wrote the wrong measurements, doh, should have read front 880 mm, rear 885 mm.
Mick
Post #200666 10th Jan 2013 9:58pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
standard spring seat to seat height for a TD5 90 are ~260mm front and ~300mm rear. Not sure if these altered with PUMA.
if you dont want to get dirty then these are approx heights for a 90 centre of hub to lower arch...
RH Rear 52.3cm
LH Rear 50.4cm
RH Front 52.3cm
LH Front 51cm
as per Ibexman's post rubber spring isolators give you back ~15mm and with a Hi-Lift takes about 5 mins to fit both.
Steve
Post #200680 10th Jan 2013 10:29pm
