Home > Puma (Tdci) > performance, Cruise Control & Steering wheel
Page 2 of 2 <12
DAM
United Kingdom 2012 Defender 90 Puma 2.2 SW Rimini Red
The Terrafirma one i think is factory but as we all know that isn't always best so i'll have another look and decide
thanks regards
David
Post #199842 7th Jan 2013 11:33pm
Factory for which vehicle as cruise has never been offered on the Defender by the factory ?
Post #199860 8th Jan 2013 7:10am
DAM
Here's the link
http://www.terrafirma4x4.com/mobile/search...se+control
There are two options regards
David
Post #199861 8th Jan 2013 7:24am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Go Beyond wrote:
I have just (last weekend) installed the Mobile Centre cruise control into the FCX 130.
I can't comment on it's operation as the vehicle is still being assembled, but I can comment on the quality of parts (excellent) and the ease of installation .... one hole in the steering column cowl to install the stalk, plug and play connection at the throttle, 1 wire to the clutch switch (engine side of bulkhead - easy to access), 1 wire to brake pedal (again easy access), live and earth - Bobs your mothers brother Thumbs Up
I had a quick Google search to compare the Terrafirma one and apart from the price (which is very similar) I couldn't find pictures or spec Confused
Where do these units connect to monitor the vehicle speed..? I guess it needs another connection..?
Simon
Post #199867 8th Jan 2013 8:17am
Quite right, forgot that bit Embarassed
Single connection to dash clocks loom
Post #199871 8th Jan 2013 9:14am
DAM
Details of the TERRAFIRMA CRUISE CONTROL KITS
The electronic cruise control Kits are available for 2002-2007 Defender Td5 and the newest 2007 on Defender Td4.
Functions are controlled by two buttons. The speed is adjusted using the SET button. When this button is held down, the Defender accelerates; when it is released, the Defender maintains the current speed.
The second button, RESET/RESUME has two functions. If cruise control is active, pressing RESET/RESUME deactivates it. When it is pressed again, the most recently stored speed is recalled, and the Defender gradually accelerates automatically until this speed is reached.
Cruise control is also deactivated when the brakes or clutch are used. Cruise control can generally be used at speeds of 45 km/h and above.
TFCCK Terrafirma cruise control kit - Defender Td5 2002-2007
TFCCK07 Terrafirma cruise control kit - Defender Td4 2007- on
TFCCKTD5 Terrafirma cruise control kit - Defender TD5 1998 to 2007
[/img] regards
David
Post #199927 8th Jan 2013 2:30pm
http://www.defender2.net/forum/topic2266.h...p;start=60
More info here - there was a solution from Sonic3d/Allisport...
Post #199952 8th Jan 2013 3:59pm
couplands
Alive Tuning wrote:
Alive will be releasing an all new billet steering wheel boss for 36 and 48 spline fitments, very soon. Avoid the Momo and Mountney bosses, as they're very poorly made, and you'll have problems with them fouling on the steering cowl, and the indicators not cancelling.
You can be sure we'll have a lot to say about the 2.2 remapping, as soon as it becomes available. In the meantime, keep away from common rail tuning boxes, if you're planning on keeping this car.
Any details on the boss, I'm looking at the Momo Tuner wheel, will it work with that model..?
Simon
Post #200159 9th Jan 2013 12:15am
series1
I can't comment on it's operation as the vehicle is still being assembled, but I can comment on the quality of parts (excellent) and the ease of installation .... one hole in the steering column cowl to install the stalk, plug and play connection at the throttle, 1 wire to the clutch switch (engine side of bulkhead - easy to access), 1 wire to brake pedal (again easy access), 1 wire to loom behind dash clocks, live and earth - Bobs your mothers brother Thumbs Up
Go Beyond, how did you locate the right wire from the dash loom? I assume this is for the speed or rpm signal. I am about to install a Mobile Centre cruise control to a 2011 90 and the rest seems pretty straight forward. Thanks for any tips!
Cheers from northern Finland!
Post #203592 20th Jan 2013 3:59pm
Killer90
Site Sponsor
Gary is right the mountney boss is horrid and fits really bad, i have one of the Alive boss's on my 90 and it really is the bomb Thumbs Up Other wise the ones which are on my site for sale are also really good and work correctly with indicators etc Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #203593 20th Jan 2013 4:07pm
Hi Series1, the instructions give the PIN number of the plug that goes into the back of the instrument pod.
Unplug it and its quite straight forward, although mine is probably easier as I have the dash out Mr. Green
Post #203604 20th Jan 2013 4:49pm
dgardel
Italy
Alive Tuning wrote:
I've seen a 320mm steering wheel fitted, and they're way too small! The difference between the 350mm and 320mm is immense. Shocked
First, agree with the common rail boxes, keep away!!!! Your engine Will be happy
Second, the right dia for the Defender steering Wheel mod is 360mm or, better, 380mm but this diameters are not easy to look for.....
The 360mm
And the (actual) 380mm
both Nardi and the boss is Nardi also
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #203606 20th Jan 2013 4:51pm
TJ101
My cruise kit was from Sonic3d/Allisport , a few years ago now ,,
Was then not a plug and play, but easy enough to wire, most into the throttle switch,,
The speed input was a small problem, as the pulse from behind the dash was not strong enough !! so when back to the speed sensor on the gearbox,, easy enough Smile
Cruise must be in the top 3 of mods fitted, and fitted in a way, that it will be coming off and put on the next 110 Rather than drilling for a stalk switch, silver switch panel on the center panel
350mm Momo Nero for me Thumbs Up standard boss, never had a problem
Recon my remap has lost maybe 10% fuel consumption !! but then i may drive it a tad harder now ! Shocked
struggle to better 22mpg, probably down to 265 tyres, roof rack and RAI etc ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #203636 20th Jan 2013 7:04pm
Page 2 of 2 <12
