![]() | Home > Technical > Wanted to borrow: Steering wheel puller |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
That's what I meant, gonna have to make one I think ![]() |
Do not fret it is really easy to make a steering wheel puller, took maybe 20 mins, I did it on Saturday, worked a treat. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Smart
![]() But shout it at them in German because life is also terrifying and confusing... |
Thanks, the leather feels really good in your hands. I went for the same diameter as standard, which being more slimline means you can see more of the dash. The only little quirk is that the full beam to dipped beam lever is a bit of a stretch (finger tips) I will bend the arm a little later on today... ![]() |
yorky Member Since: 25 Aug 2012 Location: West Yorkshire Posts: 119 ![]() ![]() ![]() |
How did you get on with bending the stalks? I fitted a Momo wheel recently and I've developed the stretched finger technique to operate the stalks, not a major problem but if bending the stalks without causing an issue is easy then it's worth doing.
![]() Volvo V70 |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1446 ![]() ![]() ![]() |
Really like the mota-lita wheel. The only bit I dont,t is the gap created by the need for a boss(on all aftermarket wheels). Like DieselJjims solution, just need a workshop and welder. RDX do a slimline boss, although this still looks big to me. Dose anyone know of real slimline boss, that looks more OEM ?
