![]() | Home > Maintenance & Modifications > Dif-lock reengaging |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
Have you tried turning the steering to full lock and reversing a short distance? That always pops the lock out if the mechanism is in fact disengaged. If that doesn't work then it seems that there is a problem with the actuating mechanism. 2005 Td5 | 90 Station Wagon | Tonga Green
megatoad Member Since: 07 Jan 2012 Location: Hertfordshire Posts: 358 ![]() ![]() ![]() |
Thanks Green Machine.
I tried driving around in circles on a loose surface both forwards and reverse, even trid speeding over speed bumps and kerbs to see if it would jolt. As I said though, I finally jacked a front wheel and managed to get it to temporarily dissenage, then when I drove it down the road it re locked! Jacked it again and the wheel would only rock back and forth against the transmission play. This time it would not dissengage using the lever. He who dies with the most toys wins ![]() Defender 90 & 110, S1 80", Disco 1, S111 88 LRSOC & CVLRC |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8375 ![]() ![]() ![]() |
have you tried operating the lever from under the vehicle with a pry bar? ie going straight onto the actuator?
as an aside, with the engine running, hand brake on (hard) if you select reverse and lift the clutch slowly (no footbrake) this will disengage difflock assuming it all works as it should. you will not have to lift the clutch fully. any difflock preload (? not the right word but it currently escapes me) is normally induced by fwd momentum. if you lock one part of the transmission (ie rear prop) and select rev you in effect spin the front prop against the rear releasing the torque that was holding the diff lock in. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
I think I will let the pros look into that
Got the AA to take it back to the dealer, when I asked the driver if he knew the way he said yes as he had just dropped a Range Rover off there ![]() ![]() Click image to enlarge He who dies with the most toys wins ![]() Defender 90 & 110, S1 80", Disco 1, S111 88 LRSOC & CVLRC |
