![]() | Home > Puma (Tdci) > Back door adjustment. |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
I'd be interested on how this should be done too. Mine could do with a tweak, but I'd not tried up until now as I had no idea on the correct procedure.
Pete |
Cracka Member Since: 08 Dec 2012 Location: New South Wales, Australia Posts: 129 ![]() ![]() |
Ahhhhh Pete,
I got all excited then, my email alert chime went I thought beauty, over 150 views and my first answer. Logged in only to find your having the same issue getting an answer, it must be part of the dark arts and nobody wants to let us in ![]() ![]() Did you have a go at your door Pete, if so did you have any adjustment available, I'm guessing not as you have posted here ![]() I hope somebody can give us some guidance on this, pleeeeeease ![]() Mick. |
I would have a quick check on the whole rear panel being "square". Take a diagonal measurement say from a common point on each side of the cross member to a like point on the gutter just incase the back of your motor is on a "slant" or out of true due to an accident or woe betide LR didn't build the thing "square" in the first place
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 671 ![]() ![]() |
Undo all bolts on the 3 hinges on door side. You should then have enough movement to adjust to desired position. Once happy, tighten one hinge at a time,I tend to start with top. Then, check position after tightening each hinge. If ok carry on, if its moved go back and adjust. You only really need to adjust top and bottom hinges as the door can be fully held without movement by these two. Then, once happy, finally tighten middle hinge.
Cheers Steve |
You could need new brass balls in the hinges as these ware over time causing the door to drop. I'd recommend putting a full stainless rear door hinge bolt set in at the same time, these can be found reasonably cheep on uk eBay or I'm sure some of the site sponsers may supply them
![]() Ray |
Sorry to get your hopes up there with my reply, but no I haven't touched it. It's only two years old but been slightly lower on the LHS from day one. Functionally it works fine, doesn't touch anywhere and doesn't leak. It's more of an aesthetics thing in my case. Pete |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
When I went on the Solihull Defender factory tour I watched them fit the rear doors
![]() One man in a brown overcoat held the door roughly in place, whilst a second man dressed in identical attire used a drill to drill holes through the hinges and into the body. He then passed some bolts through and tightened the nuts up on the inside. Done!! So as for 'how do LR adjust the door', I guess they don't! |
Egghead Member Since: 25 Nov 2012 Location: Surrey Posts: 256 ![]() ![]() ![]() |
Jee whiz, when I first read that topic title I had a fit of the school boy giggles!
Thanks a lot for the advice guys I do appreciate it.
JWL, I will look at the 'squareness' issue, hopefully that won't be the issue. Mk1collector, the hinges themselves are tight, there is absolutley no movement when trying to lift the door when open slightly. I should have put in my post the car is a March 2012 with 10000 kms on it. SteveG, I will give that a go to see if there is adjustment there as I only tried on the body side. Egghead, ![]() I will report back when I have some results, have got some 'house' stuff do do today. Mick |
If its that new take it back to the dealer and get them to sort it
Yes I know I should, but if I can find out how 'they' do it, it would save the the nearly 6 hour round trip, hence the reason I started this thread. And no doubt they will only give it to the apprentice to sort out, I don't mean any disrespect to apprentices by that comment either
![]() Mick |
