Home > My Defender > 110 XS Utility Station Wagon
Page 5 of 5 <12345
If you want them recovered Russ give me a shout, I can probably produce BP mans suggestion as well Mr. Green
Post #197452 30th Dec 2012 9:33am
BigRuss
Today I stripped out the carpet from the rear of the defender and covered the floor and wheel boxes with dynamat extreme.
I have discovered that a bulk pack is enough yo cover the rear tub Thumbs Up unfortunately I had an incident where on of the sheets folded in half and stuck together and they don't come apart Big Cry
On refitting the carpet, trim and lashing eyes I sealed the holes the lashing eyes bolt through Thumbs Up
Tomorrow I shall finish dynamating the rear panels. Russell
2011MY 110 XS USW Black
Post #198447 2nd Jan 2013 7:21pm
Russ, haven't you got a job to go back too ? way too much time enjoying a 1-2-1 with your defender Mr. Green
Post #198500 2nd Jan 2013 9:48pm
BigRuss
Yeah soon Big Cry
But then it will be back to 1-2-1 time with me and the defender Mr. Green
I wonder what I should do next time??????? Russell
Post #198515 2nd Jan 2013 10:49pm
batteries next mate Thumbs Up
Post #198554 3rd Jan 2013 8:10am
BigRuss
But I though you said bonuses where for buying watches Whistle Russell
Post #198589 3rd Jan 2013 12:38pm
Post #198635 3rd Jan 2013 2:20pm
BigRuss
Day 2 with the dynamat.
Today I finished dynamating the upper panels in the back of the utility. As you end up having a few off cuts with dynamat but all come in handy, I dynamated the rear door with a patchwork quilt style of dynamat off cuts.
I also discovered that as I lost a sheet of dynamat yesterday because it stuck itself together, I need one more sheet to finish off the side panel of the rear tub Big Cry Russell
Post #198688 3rd Jan 2013 5:40pm
mk1collector
How many sheets in total did you use and did you do the roof or just the tub and sides?
Ray
Post #198700 3rd Jan 2013 6:29pm
BigRuss
Ray,
I have so far used........
15 sheets of dynamat superlite on the roof and upper sides, rear quarter lights and rear door. (see pictures on page 4)
8.3 sheets of dynamat extreme on the rear tub.
One bulk pack of superlite (contains 12 sheets) is enough to cover the entire roof and have 1 sheet left over which would more than cover the rear door as you have a station wagon so no need to cover the upper sides or rear quarter lights.
Just remember all off cuts can't be used Thumbs Up Russell
Post #198709 3rd Jan 2013 7:19pm
mk1collector
Great thanks, I'm just trying to price up what I need to do it all at once Big Cry it's expensive stuff!! I was going to stick closed cell foam (about 10 mm thick) on top of the dynamat before putting the trims back to add a bit of insulation and stop condensation over winter.
Ray
Post #198711 3rd Jan 2013 7:32pm
Romadog
Be careful as 10mm may be too thick when replacing the side trims. I used camping mat on top of Dynamat Extreme, and found that it was enough. If the need for thicker is required, then double the thickness !
Post #198745 3rd Jan 2013 9:35pm
mk1collector
Thumbs Up thanks. I was going to pull the trim off to have a look and see what would fit before I went for it but ill just order some 3 or 4 mm stuff now.
Ray
Post #198747 3rd Jan 2013 9:41pm
993porky
United Kingdom 2002 Defender 90 Td5 HT Baltic Blue
How much does this dynamat stuff cost?
Post #200405 9th Jan 2013 10:34pm
BigRuss
you have to shop around, one place had it on sale the other week for £119.99 for a bulk pack but normally you can get it for £130 - £140 a pack Thumbs Up Russell
Post #200443 10th Jan 2013 7:30am
Page 5 of 5 <12345
