Home > Technical > Wanted to borrow: Steering wheel puller
Page 2 of 3 <123>
ken wrote:
I,ve got some det cord Very Happy
A tad over the top I would suggest Ken Shocked Laughing
Post #198655 3rd Jan 2013 3:26pm
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
Get it up to about 65 mph. The vibrations will help while you pull.
Post #198656 3rd Jan 2013 3:40pm
Laurie
Easiest way is to slaken the nut.
Finger tighten it.
Re bend the lock tab and take it for a drive.
Worked every time for me.
Post #198657 3rd Jan 2013 3:45pm
Caterham
Thud
you beat me to it....I was going to suggest (for those brave enough).....take it up to about 7 or 8 mph in FIRST gear and I hope the steering wheel falls off before anything else due to severe vibration !!!
(don't ask Sad ).....
anyway good luck - Hope you're sorted soon.
Post #198658 3rd Jan 2013 3:52pm
JeremyJ
You done it yet?! The suspense is killing me!! Very Happy
Post #198662 3rd Jan 2013 4:32pm
ZeDefender
Use a little storm lighter to gently warm the wheel just around the splines - I've done this successfully before... but not on a Defender Whistle Tell someone you love them today because life is short.
Post #198669 3rd Jan 2013 4:43pm
mk1collector
Or pour boiling water on the nut the pull at 3 and 9 positions
Post #198673 3rd Jan 2013 4:49pm
ZeDefender
In my case, the nut wasn't the problem, it was the contact between the wheel and column.
I have warmed my nuts up before twisting them in the past though... Tell someone you love them today because life is short.
Post #198677 3rd Jan 2013 5:02pm
mk1collector
Rolling with laughter I meant where the column and wheel join, I think my mind is going soft from spending so much time with the kids over Christmas Big Cry
Post #198682 3rd Jan 2013 5:20pm
Caterham
surely all this yanking, twisting and warming your nuts up somethings surely fallen off by now Shocked
Post #198775 3rd Jan 2013 10:50pm
Killer90
Site Sponsor
on the wheel with the land rover badge in the middle there is holes in them which will take a m6 or m8 bolt cant remember which but if you stick them in you can do them up to put pressure on the wheel causing it to pop off Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #198786 3rd Jan 2013 11:11pm
Once you finally get the wheel off, subsequent removal is much easier if you put a smear of copper grease on the splines before refitting the wheel.
Post #198806 4th Jan 2013 12:14am
landyman37
Have you tried tieing the steering wheel to a wall and driving off (make sure you duck).
Phil
Post #199008 4th Jan 2013 9:07pm
df1
I made a steering wheel puller a while ago for tractors big cutting the big end off a Conrad, slip this on behind the steering and use a standard 3 leg pullers.
Post #199404 6th Jan 2013 3:11pm
Merlin
This is what I used:
http://www.ebay.co.uk/itm/Landrover-specia...1c2ef09e35
But, if you then fit a different wheel, it doesn't work!
Merlin
Post #199414 6th Jan 2013 4:16pm
Page 2 of 3 <123>
