Home > Technical > SVX headlights - aux high beam level adjustment
Page 2 of 2 <12
ericvv
Daniele, which 100 Ah battery did you buy?
If I ever have to change it any time soon I was thinking of a Varta AGM G14 which is a 95 Ah battery. I believe they are good quality, and also would fit in the standard battery space of the Defender, so a direct replacement.
But I am always open for better suggestions...... You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #198189 1st Jan 2013 6:53pm
dgardel
Italy
No AGM, a good AGM cost around 450€, I payed mine 120€ (with a very very good discount Whistle )
If my new battery will run for another 4 years.... costs calculation are done! with 450€ I can provide 12 years of power to my Defender Whistle Whistle Whistle
Remember that a battery with a good contest (good Car charger circuit) have an average life of 3-4 years, everything more is given.
I choose and Exide Premium EA1000EVO (100Ah, 1100A for start) but the EA1000 is perfect (100Ah, 900A for start).
Let me know Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #198195 1st Jan 2013 7:09pm
ericvv
dgardel wrote:
I choose and Exide Premium EA1000EVO (100Ah, 1100A for start) but the EA1000 is perfect (100Ah, 900A for start).Let me know
Daniele, are both those batteries direct replacement for the standard Varta battery in the Defender? I mean are they the same dimensions?
Tks, Eric You never actually own a Defender. You merely look after it for the next generation.
Post #198198 1st Jan 2013 7:13pm
dgardel
Italy
Yes the same dimensions and lock base type, 100% plug and play VS the original one (Varta)
Exide PERFORMANCES DIMENSIONS
TXT_CODE__CAPACITY__Ah____Lenght (mm)____Larg. (mm)____H (mm)____HOLD DOWN
EA1000_______100_____900____353____________175___________190____________B13
Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #198199 1st Jan 2013 7:19pm
ericvv
dgardel wrote:
You do not need to lift the surround.
See here
You can arrive to the level adj screw with a "+" screw driver from here There is a hole on the "bend" of the screw that take on place the plastic surround to the car
Just worth stressing this for all Defenders with a SVX style front. Daniele's suggestion really works for properly levelling the aux high beam lamps easily without having to take A-bars and the entire plastic radiator/lamps fronts off.... Had the impression from earlier responses that this was not really common knowledge yet.
My aux high beam lamps for the first time in 4.5 years now are properly levelled :thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  You never actually own a Defender. You merely look after it for the next generation.
Post #198460 2nd Jan 2013 7:48pm
dgardel
Italy
Thumbs Up Thumbs Up Thumbs Up Thumbs Up
Thank you! Bow down
But, like you know, I installed myself the SVX style grill, so it was easy for me to understand how to ........ Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #198492 2nd Jan 2013 9:27pm
ericvv
Thank you! Bow down
Daniele, so much is clear yes, you really figured it out, and I think many of us will benefit from this.
Next thing is that I will inform the head mechanic at my Land Rover dealer here in Geneva how to do this Rolling with laughter Rolling with laughter Rolling with laughter
My aux high beam lamps came from the factory pointing too low. Tonight have been driving on some dark roads here and now that they are properly leveled the combination of the Speaker high beam plus the aux high beam is just fantastic Exclamation No need for more than that Exclamation
Post #198510 2nd Jan 2013 10:13pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
That's good to know guys. I've fortunately never had to adjust mine. The dealer must have set them up properly when they fiited the front to the 90 when it was new.
That's another reason to add to the list of why to buy some 8700's, so you never have to take the front off to replace bulbs!
Pete
Post #198519 2nd Jan 2013 11:22pm
ericvv
XS Pete wrote:
That's good to know guys. I've fortunately never had to adjust mine. The dealer must have set them up properly when they fiited the front to the 90 when it was new.Pete
It is probably more of importance to those like me who have bought a SVX, ICE, X-tech,.... which have those fronts slammed on at Solihull already Rolling with laughter . In my case for sure, neither there, nor at the pre-delivery inspection at the dealer here, bothered to check proper levelling of those aux high beam lamps. You never actually own a Defender. You merely look after it for the next generation.
Post #198555 3rd Jan 2013 8:30am
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
It's sad that you feel that way Eric, I have full confidence in my alignment from the dealer I purchased from and have nothing but the upmost certainty that they will support me in any issues that may arrive if any (gulp) Wink. Chesterfield Land Rover that is. ===================================
Steve
90 xs sw in Stonoway Grey - Sold
110 USW X-TECH
Post #198577 3rd Jan 2013 12:05pm
ericvv
Why you say that? It is a fact now that I have learned how to adjust the aux high beam lamps from Daniele, that it is clear that they were very ill regulated at the factory for starters. My LR dealer here in Geneva are probably one of the best that exists in the industry, but also they were not able to really properly level these aux high beam lamps after I asked to do so when I had the Speakers installed by them.... As said my dealer has proven to go out of their way to help when it is necessary, but some things get amiss, can happen of course. I am just restressing this solution by Daniele as can well imagine that others with a ex factory SVX, ICE, X-tech, etc. have similar issues with the aux levelling... And there is a quick and easy solution, which if you read back up the thread clearly was not in the know by others too. The good thing is that with joint forces we can learn to correct certain things ourselves Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
Post #198584 3rd Jan 2013 12:23pm
Lishlandy
Wow, no offence intended, from your previous post it seemed that you had lost confidence in your dealer for not being able solve your issue, the problem with writing I suppose, open to misinterpretation Smile is nice to see you DO have confidence in them, I know quite a few who are not as happy as you am I Sad
Indeed we have all learnt Smile ===================================
Steve
110 USW X-TECH
Post #198585 3rd Jan 2013 12:29pm
Page 2 of 2 <12
