Home > Maintenance & Modifications > What turrets and rings?
Glynparry25
After recently changing the front springs and shocks on the Deefer I have been loving the ride...... but...... today I got some awesome articulation and managed to dislocate the front spring Sad so looks like I now have an excuse to order a set of front turrets and dislocation cones Twisted Evil .
I will be going for combination HD turret ring with dislocation cones cones, and standard height turrets.
What recommendations do you guys have? (any sponsors have anything?)
Glyn Dog Sheep
Post #198417 2nd Jan 2013 5:42pm
bob neville
Glyn
I have these turrets
http://www.devon4x4.com/index.php?page=sho...;Itemid=14
and these rings
Both fitted on the 90.
I not fitted cones .... yet Whistle
2013 Defender 90 CSW - sold
Post #198448 2nd Jan 2013 7:28pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Yep go for the Devon ones jake will sort you out with a good deal
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #198470 2nd Jan 2013 8:17pm
landy andy
Gwyn Lewis for me, cheaper, and are turret and relocation cone in one and cheaper.
http://www.gwynlewis4x4.co.uk/page51.html
Andy
Post #198527 2nd Jan 2013 11:52pm
Glynparry25
Wow, I LOVE the Devon ones, they look awesome. But my gut is saying to go for the Gwyn Lewis ones.
I am running Koni adjustables and the GL setup will make adjusting them a breeze, and the way they are made aso means I won't have to remove anything to fit- just the shock top mount and the 4 turret ring nuts so could be much easier- plus I do like his competition spring retainers Smile
Cheers for the input chaps.... looks like it is time to start spending some monies Smile
Glyn Dog Sheep
Post #199173 5th Jan 2013 3:00pm
sc70
Wales 2015 Defender 90 Puma 2.2 CSW Santorini Black
Gwyn Lewis Thumbs Up Keep your money in Wales
Post #199210 5th Jan 2013 6:40pm
landy andy
Must admit very happy with mine, but normal Gwyn, not pretty, heavily galvanised, and he just writes left and right on them with a big marker pen Mr. Green
Andy
Post #199211 5th Jan 2013 6:44pm
markb110
Hi Glyn
Just seen your post.
The Gwyn Lewis combined turret and spring dislocation cone is for a + 5 inch shock. Not sure what length of shock you have but these will not work with a +2 shock as you will then reduce your downward travel or snap one of the fittings.
A standard height turret works best, which ever make you go for as well as separate cones and heavy duty rings. Dont forget the lower spring retaining brackets. Gwyn Lewis has the best solution here as they allow the spring to stay in the vertical plane whilst the axle is dropping.
When you get the cones it is worth looking to see how Gwyn Lewis has profiled the front of his combined turret/ cone and see if you can do the same. The reason is that during articulation the cone rubs the paint off the front of the shock.
Gwyn Lewis both profiles his combined cone whilst the turret part sits back about 10 degrees. Adrenaline 4x4 take a different approach by shortening their caster corrected radius arms by 10mm to again stop the shock from rubbing.
Rubbing the paint off is not the end of the world but as you are looking it is worth considering making a modification before you put it all together.
Another thing to look at is the rear dislocation cone. I have just changed mine from the chassis mounted to the relocation cones that fit to the axle instead. The spring in turn is bolted to the chassis. The advantages are better relocation of the spring without the possibility of the spring missing the cone and hitting the tyre. Also they are quieter in operation.
I hope this helps.
Good luck
Mark
Post #199328 6th Jan 2013 8:18am
Ahem.... relocation cones... Whistle
Post #199329 6th Jan 2013 8:21am
