Home > Td5 > Heater blower modification?
Page 1 of 3 123>
Gareth
Has anyone heard or thought about modifying the blower motor controls on a Def TD5? (or Tdi as I presume they are the same)
As standard, it has 3 settings,
Off
On a little bit
Full on hair dryer mode!
I wonder if it would be feasible to fit a more modern speed control with more than just the two switch positions. Perhaps incorporating a multi position rotary switch in place of the never used headlamp level knob?
I have no idea how the motor is controlled, but I presume in a modern car it is achieved by switching a circuit with more or less resistance?
Am I making sense or talking ballcocks? 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #198390 2nd Jan 2013 4:46pm
Laurie
I've never seen a talking ballcock.....
Post #198394 2nd Jan 2013 5:02pm
Retroanaconda
The motor control circuit is fairly simple. An ignition switched 12V feed is fed to the blower motor from the fuse box. This is then earthed by the speed switch on one of two wires - one of which has a resistor to limit the current and produce a slower speed.
It would be easy enough to remove the resistor etc. and just wire the feed in via a variable speed controller or similar, this would give you a fully variable motor speed.
Post #198395 2nd Jan 2013 5:05pm
Laurie
Don't use a variable resistor on the dash. It will get hot enough to melt plastic.
Post #198397 2nd Jan 2013 5:08pm
Retroanaconda
I meant something like this:
http://www.ebay.co.uk/itm/200762259776
Though not that specific one, as I doubt 10A is sufficient for the blower motor.
A PWM controller will give you full control of the fan from zero to full whack, with no loss of torque (not that that's particularly relevant in this application).
Post #198402 2nd Jan 2013 5:17pm
The likes of the older Rover cars (25's etc), used a multi position switch, rather like that of the headlight levelling switch on defenders (although I'm not certain if the innards are the same,as in, current carrying capacity) and this switched the earth back through several large wire wound resistors behind the dash (well, from the factory they were poxy coils of wire, but most seem to have been changed to WW resistors after the old wire snaps off)
So you could mount something like that behind the dash, not toughing anything else so they don't melt.
Here's a before & after wirewound vs. old coily things:
This would give a 4 speed control (off, resistor 1, resistor2, resistor 3 then full on hairdrier mode)
Can't imagine it would be hard to knock something up to fit a defender dash, especially a td5 withough headlight levelling, as you'd have somewhere to mount the switch. You would still need the mechanical cable on the heater control to open & shut the flap.
Post #198405 2nd Jan 2013 5:23pm
VeeTee
Netherlands
I am busy with this project. Bought this PWM module:
If properly installed (w cooling), it's 10A rating is more than sufficient, it has proven it self already in a number of Defenders of fellow drivers here in the Netherlands. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #198438 2nd Jan 2013 7:10pm
skrettis
2006 Defender 110 Td5 SW Java Black
Have you got more information about this fan control project?
Post #287821 5th Dec 2013 5:44am
geobloke
This is a good idea if you want to be able to have a larger selection of intermediate fan speeds between off and full. This modification will, however, not increase the speed of the fan as you only have 12v to play with and that should already be being achieved with the standard Defender switch. I seem to remember increasing the voltage to the Defender fan being discussed on this forums previously, but cannot recall the outcome.
Post #287853 5th Dec 2013 9:34am
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
Hi Skrettis,
Here's a Google translated link of a Dutch website that explains more about this mod:
http://translate.google.be/translate?sl=nl...mp;act=url
There's a lot of other interesting stuff on this site too Wink Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #287941 5th Dec 2013 4:23pm
Mean Green
Is there an idiots guide anywhere on how to do this mod. I think my heater is fine on full blast, but a bit more control would be nice. I am just too busy to try to work it out. But if someone had a, get A + B and do X,Y,Z and its done type guide then I would probably do it.
Post #287968 5th Dec 2013 6:28pm
Romadog
Post #287972 5th Dec 2013 6:38pm
Anderzander
I've thought of opening the blower up to change the resistor value and make the lower speed a little faster - however a variable resistor would be good.
Any thoughts on where to mount the control ?
Post #287979 5th Dec 2013 6:54pm
Anderzander
I've just looked at the Dutch link - that looks a great solution !
I'm looking on a small phone screen but I like the fact that it seems to look like a factory fit.
Post #287990 5th Dec 2013 7:44pm
Gareth
Yes, like that. This seems to be a solution to my original idea. I think I will order one and give it a go. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #288019 5th Dec 2013 9:53pm
Page 1 of 3 123>
