![]() | Home > In Car Electronics > My radio has become a free spirit..... |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6205 ![]() ![]() ![]() |
Could be worth getting a can of spray contact cleaner, douse the buttons with it and repeatedy push them lots of times, see if it cleans them up... you may have a sticking button?
My dad had the same problem, and cured it by holding the traffic button down for a while, rather than just pressing it. The button was a bit tempremental
![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
Try disconnecting it completely and then re-connecting it up(after 20mins or so) so that you have to enter the security code in. This might re-start it and clear any errors messing it up. Failing that if you have traffic updates off I can't think of much you can do. Except for perhaps upgrading to an aftermarket unit.. If you wanted just CD and radio from one a good premium band head unit would only cost you around £50 - £70 and would be plug and play. Not sure what an OE LR radio would cost probably £100 + at least. ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
On most models with RDS (Radio Data System) one can select a favorite PTY code (Program Type). May be you selected (by accident) the "News" PTY code ? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Instead of a total disconnect is there not a reset button, I only ever delve into the el-cheapo end of the market for ICE but there has allways been a reset button often just a small hole under a removable fascia into which I poke a cocktail stick(non conductive in case it's the wrong hole
That's true. Trouble is some do some don't. I can't remember if mine does or not. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
jerseyman Member Since: 21 Jul 2009 Location: Jersey Posts: 279 ![]() |
Mine randomly changes channels, the only solution I have found so far is to switch it off
Could well be due to poor reception. I find I don't use the radio much for that reason. Could do with a booster really but personally I don't feel it worth the effort. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1401 ![]() ![]() ![]() |
Thanks for the suggestions - a good few ideas there... Euro-Leafing to infinity and beyond.....
Well it was the 'PTY' option, selected by holding the info button in for a while, and removed the same way. I read the instruction book, and all became clear......
