![]() | Home > Maintenance & Modifications > 110 Expedition Suspension mods |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
Forgive me if I'm speaking out of turn but, I have a 110 with a heavy duty Brownchurch rack on which is covered with chequer plate, I have overloaded the thing often in the course of my now discontinued business(35 sheets of 11mm osb isn't the lightest thing to put up there
I would look more to loading with more thought to weight distribution and save your money to further your trip. |
| Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015
Unfortunately you can't really have the best of both worlds. It is working out the best compromise.
Twin Big-bore shocks with Standard springs will be a mistake.... You will find it is over dampened which will make the suspension jar more. When doing shorter corners the springs on the outside will compress less, but on longer corners i will compress to the same height as before the shocks..... bit will take longer to stabilise after. The only way to prevent it from 'swaying is either A. Stiffer springs B. Stronger ARBs. The problem with the above thought will directly impact when you are unladen. Other option would be to install airbags inside the rear springs (instead of the helper springs). You can then put air in them when loaded and let it out when unloaded. Also to consider.... What roof rack have you got? Defender gutter is rated to a maximum of 150Kg (including the rack). The average rack is about 40ish Kg so you can only add another 100Kg. If you then have a roof-tent you have about 50Kg to spare (a couple of jerry cans). As JWL has mentioned try and re-distribute your items or maybe get a trailer. Glyn |
| pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489
I agree with JWL. I would look at your loading situation. If you only have minimal weight up there at the moment, Roof tent, couple of Jerrycans and some camping wood then i would have a look at your suspension. On my exped prepped 90 i have Koni Heavy Track Raid Dampers and Eibach progressive springs with no Anti Roll Bar and it handles perfectly. On my roof i have 2 large spacecases (light stuff, sleeping bags etc) a couple of jerrycans and some wood.
As Glyn said airbags are really good if you only have the vehicle loaded some of the time as they allow for a softer ride when you are empty and a good ride when you are full. Air Springs http://www.devon4x4.com/index.php?page=sho...;Itemid=14 Koni Dampers http://www.devon4x4.com/index.php?page=sho...;Itemid=14 Eibach Springs http://www.devon4x4.com/index.php?page=sho...;Itemid=14 Regards, Mark |
| All times are GMT |
