![]() | Home > Maintenance & Modifications > Sliding tray |
| Jammer600 Member Since: 27 Feb 2011 Location: Bath/Warminster Posts: 306
Click image to enlarge Click image to enlarge Anyone interested in this? Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939
What weight can it take once extended out? If it's a good amount then it might be useful for heavier items to avoid lifting right into the back. Just a thought. ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 625
Jammer, You have a pm. Optimists say the glass is half full..
Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
Yep just seen pm, not sure what weight it'd take to be honest, think it was held with about 4 rivets per run!? 90 Puma HT
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6018
We have rails similar to them at work for the servers, some servers weigh a fair bit. If interested I can check the weight of a couple of the servers? 1999 Defender TD5 110
Yeah if it's not too much trouble would be good for people to know if they might need that info cheers 90 Puma HT
Will have a look tomorrow and see what weight the servers are. 1999 Defender TD5 110
Ok cheers, is there anywhere that sells these? Just to get a rough price so I can put it in for sake bit? 90 Puma HT
| Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478
thats pretty neat would be good with some tie downs on the side stops bits sliding about aswell then
www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Ebay would be one option, or failing that, an IT recycling company.
Would you be after a set? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
| Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2503
I'd love to know. These would be ideal for my 110dc 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS |
I have this one in my garage! Make me an offer? 90 Puma HT
| Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808
I have made a few projects using heavy duty drawer slides. They can be rated anything up to 160kg but are more often than not designed to work vertically. Lay them horizontally and this will greatly reduce what they are capable of supporting.
Also, the prices can be a little eye watering if you wanted the system to support your body weight. As an example, the highest rated ones I could find which would extend 1 metre and support 160kg were £150 each! There are a huge range of these available with the shorter, lower rated ones being considerably less in price. For utilising the space in the back of your land rover however, the longer the better! |
Blimey, they "run" nicely but that's a bit excessive!! If some fold down props were made to clip on the side it would be proper sturdy!! 90 Puma HT
