![]() | Home > Technical > Loss of power after going through flooding... |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6015 ![]() ![]() |
I recon your MAF will be shot. This does not always show on diagnostics. Try running with your MAF unwired and compare, but better if you can fit a good MAF and compare. They are delicate things and won't have dealt well with water passing through.
Also check wastegate is freely moving. Andy |
Welly911 Member Since: 14 Oct 2012 Location: Cheshire Posts: 70 ![]() ![]() |
The initial cleaning of the sensor had no effect. Transposing another one brought her back to life. So quick sensor replacement fixed all the problems. Brilliant. Must get that snorkel fitted....
Fit a snorkel. It's height will reduce dust intake which must be heavy where you are.
NT5224 Member Since: 10 Jul 2012 Location: Robin Falls Posts: 50 ![]() ![]() ![]() |
Hi Mike
Off topic but is yours the dual cab round the back of Spinneys, Umm Suqeim? I take my laundry to the place on the corner and always stop to admire it. Haven't seen any other dual cabs in Dubai Hope you return it to robust health Cheers Alan |
