Home > Technical > Heads Up:- Air Intake System
AndrewS
Check your Box Shocked
The air filter box is not sealed to the air intake pipe that runs from the intake point on the inner wing to the air box. See pictures. So your RAI is a waste of time. I will post more pictures and hopefully a cure later this weekend. Also there does not appear to be a water outlet device from the air box.
FFS Land Rover have you lost the plot Question Evil or Very Mad Twisted Evil Evil or Very Mad
More here
https://www.defender2.net/gallery/thumbnails.php?album=53
Post #1964 25th Apr 2008 9:50pm
mse
Ill try and get a chance to check mine on Sunday.
Looking at the picture it doesnt look like that is even designed to be sealed Mike
Post #1965 25th Apr 2008 10:06pm
rmb3218
Australia
I have just fitted a TJM Airtec (Australia) snorkel to my 07 Defender. In the install they get you to remove the intake tube and seal both ends with silicone. There appears to be a water drain point at the intake tube near the guard and there is a hole in the bottom of the air cleaner that I thought was also a drain point. I was not able to completely remove the air cleaner assy, how did you do it?
Post #2033 6th May 2008 12:27pm
Japseroony
England 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
Re: Heads Up:- Air Intake System
Apparently there is a water outlet at the bottom of the airbox but this needs to be sorted when fitting the RAI.
Post #2035 6th May 2008 1:06pm
AndrewS
Japseroony wrote:
Hope its not done tooooooo much damage Question
No damage at all Thumbs Up
Post #2040 6th May 2008 7:09pm
Japseroony
Post #2050 7th May 2008 10:10am
AndrewS
No my vehicles are not re-mapped
Post #2072 11th May 2008 7:01pm
dshickle
2007 Defender 110 Puma 2.4 CSW Galway Green
Hi Andrew,
Any news on a solution.
I have fitted the RAI (thanks to your exellecent pic's, without them I whould have been stuffed).
But natually I'm concerned having seen your pic's.
David Disovery 3 TDV6 SE
Defender 90 XS 2.4
Defender 110 S D250 (MY22)
Post #2080 12th May 2008 5:30pm
AndrewS
Embarassed
When we got into checking out the air intake system we found that the RAI was not completely sealed to the wing, as the wing was deformed.
The area in the pink shows that the RAI was not sealed to the wing whereas the area in the yellow shows a clean area indicating that it was sealed.
So a couple of strips of draft excluder fixed this.
The next unsealed joint was where the ducting that is sealed to the inner wing receives the ducting that runs to the air filter box.
This was sealed internally using a water proof bandage.
The next joint was the ducting that enters the air filter box, this was sealed externally using a waterproof bandage.
I made the water proof bandages using a system I use for fixing Butyl liners for water storage tanks. You can buy similar garden pond repair kits from most garden centres.
Post #2093 13th May 2008 10:26am
dshickle
Hi Andrew,
Many thanks for this - I will now review my installation.
thanks again for your excellent service! Thumbs Up
Defender 90 XS 2.4
Post #2095 13th May 2008 11:16am
mse
Whenever i have fitted snorkels I have always used and be taught to use some bonding such as an industrial sealant.
Any reason why this would not be the case? Mike
Post #2098 13th May 2008 4:57pm
AndrewS
Cant see why not Thumbs Up Use what you are familiar with Thumbs Up
Post #2103 13th May 2008 6:16pm
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
Its interesting to read this post as recently I have noticed that the air intake noise has become more pronounced, not sure why but seems to be loudest at around 1900rpms
Post #2109 13th May 2008 9:45pm
