![]() | Home > Maintenance & Modifications > CD |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20942 ![]() ![]() |
They may have the original code for you if not they'll probably re-set it for you.
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
I.AM_a driver Member Since: 11 Jun 2009 Location: Edinburgh, Scotland Posts: 404 ![]() ![]() ![]() |
If its the originally fitted CD player then yes, the dealer can look up (there's usually a charge depending on the dealer) but if its been changed then will be more difficult. Mark S
CONVOY for HEROES www.facebook.com/convoy4heroes www.lothian4x4response.org ------ Td5 90 Thread in 'My Defender' Forum |
Whiskey Member Since: 07 Apr 2012 Location: Gibraltar Posts: 31 ![]() ![]() ![]() |
Thanks for the advice fellas . I got hold of the code . But I put on the CD to put the code number and it came's out SAFE .
Obviously I had to wait 1 hour to put the code. But! I lerned to put the number's on then you 5 and it does not go on. Does anyone now what is the problem.
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2672 ![]() ![]() ![]() |
Just in case you haven't found it in the manual:
It worked for me - maybe you have an incorrect code? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Can't remember exactly how I did it but according to my handbook, you input the code with buttons 1-4 in order, then press RND (which is also button 3) again. Not 5. It's not exactly obvious but I'm pretty sure that's what I did. It may differ between models and year.
You have to wait an hour after a 3rd failed attempt. Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... Last edited by ZeDefender on 29th Dec 2012 6:17pm. Edited 1 time in total |
Perhaps your entering it the wrong way. say you have code of 4556
Press 1 4x times press 2 5x times press 3 5x times press 4 6x times Then usually there is a final key (probably 5) to set it. Check the manual for details though... I've known an OE radio for another vehicle (Renault) that worked in this way/ ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Just in case it gets lost, on mine (with the aux in at the front) it's not 5 to finish but button 3 again... Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
Well how am I meant to know I chucked mine out of my 90 the first chance I got. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
So did I... but then I stuck it back in again ![]() But shout it at them in German because life is also terrifying and confusing... |
![]() ![]() ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
mfspannerman Member Since: 18 Nov 2012 Location: Suffolk Posts: 36 ![]() ![]() ![]() |
Happy new year
I know its abit off topic but what is the best general cd player to put in a defender with a front usb port? Make tracks and get moving!! PUTTING FOOD ON YOUR PLATE IS WORTH THE WAIT! PLEASE BE PATIENT! |
Kenwood DAB at a guess at the moment in time. Or If you would prefer a model "Made for iPhone / iPod" ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
