Home > Technical > Water in lights
boode
England 2003 Defender 90 Td5 HT Rutland Red
Water in lights
Daughter drove through very deep puddle
Small drop of water in headlights which do not work any more
How should I get it out ?
Can it be prevented from getting in again?
Post #195692 22nd Dec 2012 4:23pm
ibexman
Take it off the car or put some fish in there Thumbs Up
Post #195699 22nd Dec 2012 4:31pm
Andy Jeff
United Kingdom 1999 Defender 90 Td5 CSW Chawton White
You should absolutely get the water out as it damages/removes the silvering on the reflector at the back.
Remove the guard, the indicator, the side light and the surround then you should just have to undo one screw on the headlight bezzel and it will twist out. Don't undo the tiny screws that mount the bezzel to the headlight, it's difficult to tell them apart! Then unplug the bulb, remove the rear rubber bulb cover and unclip the bulb...but don't touch it or it will blow when you put it back! empty the water and dry the headlight out in the airing cupboard overnight! Re-assembly is the reverse process!
Andy.
Post #195700 22nd Dec 2012 4:33pm
boode
Putting fish in seems easier than light removal Whistle
One dissadvantage of the LED side lights is that they bolt from the back the the wheel arch lining has to be removed first - a long job especially in the rain Big Cry
Post #195703 22nd Dec 2012 4:38pm
grafty99
Somebody has been through Braunton Question 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #195716 22nd Dec 2012 5:24pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
I managed to just take out the first few plastic rivets and get my hand up behind the arch to undo them. Thumbs Up
Post #195770 22nd Dec 2012 7:47pm
grafty99
I managed to do mine without removing the arch spats. It is possible! Made alot easier with the liberal use of swear words Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #195780 22nd Dec 2012 8:15pm
I'd remove them empty the dirty water out then swill them through with clean water to get and dirt / muck out then dry as mentioned previously in airing cupboard or perhaps on radiator providing it isn't too hot. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #195785 22nd Dec 2012 8:45pm
Killer90
Site Sponsor
i know it sounds a waste but you could sell them dirt cheap or keep them as spares and upgrade to some nice clear ones Thumbs Up they transform the look and are very good value for money Mr. Green CSK Automotive
www.cskautomotive.co.uk
Post #195786 22nd Dec 2012 8:52pm
boode
Mananged to remove them - had to remove a few clips on left side as horn got in the way of acces from the top
Drivers side the plastic trim bent back enough to remove retaining screw. Smile
Is there any method of stopping it happening again ?
Can they be sealed ?
Post #195787 22nd Dec 2012 8:55pm
boode
They are IPF 110/80w so nice and bright - but not at the moment - so reluctant to upgrade unless I go for LEDs that wont need the bulbs changing
Post #195788 22nd Dec 2012 8:57pm
grafty99
Go on Gavin, you know that LED is the only way to go! I did some deep wading over the last couple of days, leds are still bone dry inside and fully functional Razz 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #195812 22nd Dec 2012 9:35pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
You never got that problem with the sealed beam units on the series Land Rovers,just a shame they were useless as lights ! 2005 Td5 90 XS
Steve
Post #195854 22nd Dec 2012 10:20pm
Peter
United Kingdom 2005 Defender 90 Td5 SW Epsom Green
Wanted some of these about a month ago, after a very damp trip inc headlamp water ingress back in October time. Bearmach and island4x4 cannot get hold of them, saying they are no longer made. Something about improvement to lighting using halogens. If you got a set keep hold of them for off road wading trips, easier to change a pair of lamps than the hour it took me to clean and dry waterlogged ones in the field, using kitchen towel. Whilst everyone else had lunch!
Peter
Post #196470 26th Dec 2012 3:34am
