Home > Maintenance & Modifications > Damping
grafty99
Damping
How come that the rear dampers are externally mounted at an angle? would it be of an advantage/possible to re-locate them inside the rear springs for protection and a better operating angle? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #195460 21st Dec 2012 6:21pm
ibexman
IT would be stiffer and less travel
Post #195464 21st Dec 2012 6:26pm
grafty99
would it be the same as the front then? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #195466 21st Dec 2012 6:32pm
Retroanaconda
Yes. The front axle has less travel as it is due to the different suspension setup.
In theory the best possible operating angle is vertical as you surmised, but being inside the spring limits travel and is a pain in the arse when you want to change them!
Post #195469 21st Dec 2012 6:35pm
grafty99
So changing it would give better on road control but worse offroad performance, well that answers that then ! 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #195612 22nd Dec 2012 12:48am
