Home > Maintenance & Modifications > Under side protection
Page 3 of 4 <1234>
Killer90
Site Sponsor
custom90steve wrote:
Killer90 wrote:
i have some diff guards available ( pics to follow), made to the same spec as the qt and are electro coated in any colour will be a bit cheaper than qt aswell, look identical except have csk on instead Thumbs Up
Your's will be white then .. Whistle
my new steering guard is Whistle Rolling with laughter Rolling with laughter pics to follow hopefully tonight Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #193453 14th Dec 2012 2:42pm
I'll hold you to that. Thumbs Up AND pictures of the diff guards. Whistle ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #193454 14th Dec 2012 2:44pm
Glynparry25
SteveG wrote:
steering guards are more for looks than benefit. They can get caught up on rocks and stumps, and can catch when being pulled out backwards. I've personally found fitting HD drag link and track rod bars a better option, and for full belt and braces a track rod guard as suggested above.
I will have to disagree with that. HD/ Sumo bars are great (I had a set on my Disco) but if you knock one hard- like on a rock the bar survives but the ball joint on the end get shagged. It is also still possible to bend them if you manage to hit them in the centre. With my Defender I have opted for the steering guard, and Southdown axle guard as it gives it complete protection.
A steering guard should never get caught when being pulled out backwards- it sits higher than the bottom of the axle therefore you will have already ripped the axle off to reach the steering guard.
Glyn Dog Sheep
Post #193470 14th Dec 2012 3:50pm
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
Glyn Dog Sheep
Well said.
My steering guard saved my but on a few occasions already.
Some of the tall grass in the African bush can make it real hard to spot large rocks/boulders and when you are more focused on following the pack of small lion cubs instead of really looking where you are going you can easily make friends with a huge stone.....believe me......there is no worse place to try and straighten your bend steering than between a lioness and her small cubs only a few meters away.......... Rolling Eyes
Post #193484 14th Dec 2012 4:44pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
So some examples for you from personal experience....
Driving over fallen trees, I've dropped one wheel over, only for one of the trees to tip and wedge itself between steering guard and axle. It's happened a few times in the past and is a real pain in the derrière.
Driving over rocks, again steering guard pushes over a rock and then it wedges itself between guard and rock. Same thing going out backwards.
Pulling out a Range Rover backwards in peat, with front steering guard and Southdown axle guard both acting as ploughs adding significant drag to vehicle. Meant we had to get a couple of vehicles and double line pull on one of them to extract it.
Look, nothing's perfect, just from experiences like this I chose a long while ago to not to bother with a steering guard anymore and haven't regretted it since. It's just a personal choice, and anyone can fit what they like the most. Wink
Steve Smile Smile
Post #193496 14th Dec 2012 5:36pm
Glynparry25
Steve,
By the sound of it all your incidents were at low speed doing more technical/ challenge stuff, and the only issue was the inconvenience of getting it out (hi-Lift jack for about 5-10 mins).
I am talking about higher speed (10mph+) where as with Regard you are going through bush/ taller grass/ water/ mud/ snow where you can't see rocks etc that can take out your steering bars/ diff.
Last experience I had was on a salt lake where there was scrub grass about bumper height. I was doing about 20mph down a path (grass either side and down the middle). I heard a bang- an old concrete post had been abandoned in the middle. There was a dent at the bottom of the TJM bumper, then impact marks down the steering guard and then along the axle guard. If I had HD steering bars I would have definitely been stranded. Which would have resulted in leaving the vehicle to search for recovery/ spares.
As for the recovery- For the steering guard to act as a plough/ anchor the mud needs to be deep enough to be going over the front axle. If the mud is that deep it means you are going to have to do a double line pull no matter if you have a steering guard or not. An axle guard has the cross sectional area just bigger than a HD bar so shouldn't cause a problem.
There is no perfect solution, but it fit comes to either 30mins stuck and needing more technical recovery, or spending several hours replacing track rod ends in 2' of mud I know what I will go for.
Glyn Dog Sheep
Post #193650 15th Dec 2012 9:15am
Ric
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Anyone know where I can view a fuel cooler / transmission guard online?
Can't seem to find one.
Are most if the steering guards the same size just diff thicknesses?
Sorted for diff guards
Sorted for fuel tank guard
Just need steering, cooler & transmission
Thanks its only a car!
Post #194247 17th Dec 2012 10:51am
Fuel cooler guard and transmission guard both available from Devon 4x4's on-line shop. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
Post #194249 17th Dec 2012 10:53am
Ric
Thanks Steve.
I'm wanting to see a combined cooler/transmission guard its only a car!
Post #194278 17th Dec 2012 1:37pm
jst
Steve has some valid points which he has posted from his experience.
When we ran rogue Vogue 4 (a susuki/toyota axled vehicle) we didnt run steering guards for those reasons plus the added weight and we were seldom doing more than 25/30mph on sections when competing.
the biggest benefit i think of a steering guard (and i run them on green laners and training vehicles) is protecting the drop arm. from my experience. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #194396 17th Dec 2012 7:33pm
leeds
Defender 2.4 fuel cooler
Quote:
The unprotected fuel cooler on the front left of the Defender’s frame is a risk that is not to be underestimated for everyone who drives off-road.
Upright protruding branches pose a threat of damage not only to the fuel cooler but also to the fuel feed pipes. They can be damaged or even ripped out.The only solution that makes sense is a cover that has neither drain holes in this area nor protects it only partially.
Our protector plate for the fuel cooler is made of 4mm aluminium and can be fitted very easily with no need to drill extra holes. Open upturns against the direction of travel drain off coarse dirt quite satisfactorily and are totally impervious to light contact with thick branches. Cleaning the inside of the protective plate after extensive off-road use is made easier by the plate being open at the side, so layers of dirt can simply be hosed off with water.
To fix the fuel feed pipes laid loosely along the frame, we have fitted a small lug to the upper surface of the protector plate.
They can be fixed to it easily and effectively using a pipe clip that is included with the kit. Powerful blind-rivet nut pliers – a special tool – are required to fix the protector plate.
and
In stock in the UK.
Brendan
Post #194403 17th Dec 2012 8:04pm
Ric
Right guys, thanks for your help.
QT front & Rear diff guards fitted, bruises to prove!
Steering guard ready to fit,
Fuel tank guard half fitted. Cannot get the bloody bolts to reach the front of the tank.
Clamped the two guards together, jacked up the tank/guard to help a line it all.
Going to go now and buy some longer bolts, any tips? its only a car!
Post #195312 21st Dec 2012 10:33am
Ric
Steering guard and fuel tank guard now on!
Longer bolts did the trick Rolling Eyes its only a car!
Post #195417 21st Dec 2012 6:19pm
^^^ That Entreq protection looks very purposeful and seems like a skid plate design. I would like to see the same design for the whole underside. It would then act as a giant skid plate to "slide" over any rocks or branches stumps ect. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
Post #195447 21st Dec 2012 7:02pm
Ric
Yer, I was thinking the same while laying under the car for hrs!
So many areas subject to damage,
The QT guards look ace, however they do lower ground clearance so will prob hit things I would have missed without them on Confused
I like the fuel tank guard but by putting the tow bar back on it seemed a bit of a waste Laughing
Maybe in the new yr I'll raise it an inch, when the new wheels will be ready its only a car!
Post #195485 21st Dec 2012 7:58pm
Page 3 of 4 <1234>
