![]() | Home > Td5 > Loading a standard 110 map on a 90 |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
Hi guys,
Much as i know about how the Td5 tick and how the 10AS clicks, i've always been tempted to load a 110 map on a 90. How do I do it? I'm not talking about trying to copy a re-mapped truck's ecu, but load the standard map of a 110. Is it the case of just generating it from the application and loading it on the ECU via the write map function in the nanocom. Can I possibly load the wrong map and brick my 90? If the wrong map is loading what will happen? I don't have a spare ECU to try it out, and the truck's a daily drive. it's an 02 and has the NNN ecu. Thanks! The defender has migrated, leaving the owner behind. |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 589 ![]() ![]() ![]() |
Hi,
I thought they were the same? If your brave try here http://luca72.xoom.it/td5mapsuiteweb/index.html I would get a spare ecu if your going to play... Steve ![]() |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 ![]() ![]() ![]() |
Can i ask why? What is the advantage?
Regards, Mark |
Hi Jim,
Are you talking about IRB Developments? if yes then you are not alone!! I have spent about £1500 on parts from him, now I want a remap he cannot be bothered with me. I think the forums have been very kind to him, for how long I wonder.. Bell Auto Spares on the other hand are the complete opposite, I spoke to them at the Overland Travel Show in September. He wanted to do it there and then ![]() ![]() But will definitely use B.A.S when the time comes. Regards, Steve ![]() |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
IRB must have too much money
cool, ok that sounds easy.
I'm impressed about the Td5 open maps project. Never heard of that before. I'm glad i've asked and you guys have certainty been of great help. Thanks! The defender has migrated, leaving the owner behind. |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
I read somewhere that the Discovery 2 map was better and that the discovery 2 auto map had much more torque, however that one might have other issues that dont suit a normal gearbox DEFENDER 90 TDCI XS,
