![]() | Home > Maintenance & Modifications > Heated Seats and Windscreen. |
| appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630
Ok, So I recently got a tax rebate. I've got two choices... stick in the bank, or spend it. Then two choices of where to spend it - somewhere sensible, or on my Land rover.
No really no choice at all I want to fit a heated windscreen and heated seats, want to do the work myself to keep costs low (I was a mechanic for a while so I'm competent, if clumsy). Does anyone have any advice on keeping the installation as original looking as possible? I want to use original switches to fill some of the blanks in my dash if no other reason! |
| Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812
Screen is easy....
http://www.mobilecentre.co.uk/index.php?ma...cts_id=576 From Tim (site sponsor on here). And I'm sure Tim could make up looms (using correct plugs) for the seats as well. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
| couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830
There's a good description of fitment of heated seats here:-
http://www.defender2.net/forum/topic10705-180.html cheers simon |
| Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2530
I had chip in the screen so phoned up my windscreen cover, they asked if heated or not and so naturally i said heated and they fitted a heated screen in for £50
all I have to do now is wire it in which i havent bothered as yet! 2011 Santorini Black USW XS. 2015 Discovery 4.5 Black pack Firenze red XS |
I've had a look at both those posts mentioned here, while I don't doubt the quality of the Mobile Centre kit, it does seem a little expensive for what's there. Also, I should've mentioned, I'm looking at aftermarket seat heaters to fit at the same time as I retrim the interior
Got a mate who is a windscreen fitter, couple of beers and he's happy |
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2787
Even the pros break them, that's why I suggested getting someone to supply/fit - that way if they break it they pay for it! It's an easy enough job to do with a bit of string and some lubricant, it's just the risk of busting it one has to take into account |
| mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645
Buy the relay here http://www.mobilecentre.co.uk/index.php?ma...cts_id=566 Plug & Switch here http://www.mobilecentre.co.uk/index.php?ma...cts_id=575 These are the main parts if you are looking to save a few quid and put it together yourself instead of paying us to do it |
| WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748
Got my wiring kit from mobilecentre, does the job perfectly. Got an auto electrician to connect it up though as I havent got a clue. Then fitted a mud stuff console with carling switches.
Just as an FYI it may look a little expensive for what is there but if you buy all the electrical parts from VWP it comes to a few pence short of £50 + VAT, then you have the genuine switch and connector at £15 so total parts cost to buy in would be at least £65 + VAT
The crimp tool to do the terminals in the LR switch is £400 + VAT Once you get into what actually goes into a kit it is quite suprising |
I'll think I'll stop being cheap and just buy the damn kit already! Good points, well made. |
To be honest it sometimes suprises me how much a few bits of wire can cost!
| SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455
For those looking for an entirely factory fit, I recently found a complete XS loom on ebay for £90... My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
I did a write up some years ago on how the pro's replace a screen, you'll find it here....
http://forums.lr4x4.com/index.php?showtopi...windscreen I've personally replaced a number of Defender screens and while the job is far from difficult and can be carried out by someone without experience it's easier with two people, it's even easier to slip an experienced fitter a bit of beer money to do the job for you. If you are going it alone having the screen out gives you a good opportunity to deal with any corrosion found under the screen rubber. Steve. Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
| All times are GMT |
