Home > Maintenance & Modifications > Alarm fitment
ThreePointFive
United Kingdom 1988 Defender 90 V8 Petrol HT Bonatti Grey
Alarm fitment
I am looking at options for security for a pre-puma/TD5 defender project vehicle.
Is the Land Rover alarm a standalone system or does it require the presence of the main vehicle ECU to function?
I am aware that central locking would be necessary to make full functionality possible - at least it will be if it is like any other vehicle with an alarm.
Are there any other issues with wiring in a Land Rover supplied unit?
Alternatively, is there an after market system that would be better in the way it works, and an upgrade from the standard kit? I want it to be as good as I can reasonably get. One life - get one.
Post #194544 17th Dec 2012 11:44pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
The LR "anti-theft system" has its own Control Unit but yes it also connects to the main Engine Control Module.
I think it might be expensive to install the LR one as a retro-fit. You are probably better off getting a good third party unit such as this one:
http://www.cliffordalarm.co.uk/productdeta...=4&b=2
Post #194586 18th Dec 2012 10:06am
Romadog
Assuming you're going to use a Td5 loom, if so alarm won't be a problem. If using a 300tdi era wiring loom, then its not a problem either. I have a 50th annivesrary bulkhead loom, which is a v8 300 series loom. I have up graded the allarm box to one which works cental locking as well, using Td5 wiring extracted fom a Td5 bulkhead loom.
Post #194596 18th Dec 2012 11:07am
ThreePointFive
I have the main TD5 bulkhead loom but without ECU wiring. Everything else is complete. I haven't priced up the alarm from LR so that alone could make my mind up, but then the link above is for a £500 system itself.
It sounds like it's doable anyway, so that points me in the right direction, thanks for the help. One life - get one.
Post #194711 18th Dec 2012 6:52pm
