![]() | Home > Puma (Tdci) > May 2010 TD4 drives to the right side... |
Have you tried jacking the front up so that both wheels are free from the ground. See if one side is binding as it may be that there is some dragging of brakes or a bearing binding giving the effect of letting one wheel spin easier/faster than the other. It might be worth doing this when it's cold and also after a fair bit of travel when it's warm and has shown the symptoms you describe.
Pupsi Member Since: 11 Nov 2012 Location: M�nster Posts: 7 ![]() ![]() ![]() |
I have looked at the wheels and brakes.
Everything moves free and easy. I had two different official Land Rover garages a look at it. As they can not locate the mistake they are afraid of channging parts that could cause the problem. The one standard answer here in Germany ist "it is a Defender and normal" or "we are sorry we do not know what is wrong with your car. As we have problems do get our fault search and the parts paid from Land Rover so we do nothing". (It is not possible do get direct contact do a technical Land Rover man only with the costumer departement). Defender 110 TD4 (Experience) |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 ![]() |
Your steering wheel is on the wrong side
![]() I would start with brakes, bearings etc What kind of wheels do you have?? Chris 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
It's probably not much help but I find my (German) 110 is very sensitive to the camber of the road... and many German roads (including Autobahns) have significant camber. Mine also apparently pulls to the right, although if I drive on the left side of the road (as I learned) it pulls to the left
![]() But shout it at them in German because life is also terrifying and confusing... |
1st I agree with ZeDefender
2nd check the connection from the frame and the pull rod (rear) and the push rod(front) And the silent-block/bushes... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Thanks a lot.
I hope you know that I have do do all this work outside on a road in the city centre ![]() So it will depend on weather etc. and I can not do all the checks on the road on my own... ![]() Please understand if my next reply will take some time. Nikolai Defender 110 TD4 (Experience) |
Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251 ![]() ![]() ![]() |
Hi Pupsi
Please send Naks on the forum a PM. He had a very simmilar issue that was eventualy resolved by the pannel beaters inserting some kind of very small spacer somewhere in the suspension after LR could cure his problem. |
Measure wheel centre to wheel centre on left and right side and see if they match up
One of the LR garage fited an extra shim here:
![]() Click image to enlarge It did not help. I could not talk to the mechanic as the garage had the last day opened. It then closed for ever... Defender 110 TD4 (Experience) |
Will do this as the next step... Defender 110 TD4 (Experience)
