![]() | Home > Puma (Tdci) > How to get at my fuse box? |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1320 ![]() ![]() ![]() |
fuses in two places ( at least)
Some under drivers seat as you say and a whole load in a little compartment under the steering ( in UK cars) Do you mean an idiots guide to lifting the drivers seat? If so grab the front end of the seat cushion and lift |
Why do you need to check your fuses? Is something not working? The fuse box cover under the steering wheel tells you which fuse does which. Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
Always worth checking the vehicle handbook......
![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 ![]() ![]() ![]() |
I'm glad this wasn't posted in the 'Technical' section.... ![]() 110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
rleslie Member Since: 10 May 2012 Location: Ellon, Aberdeenshire Posts: 128 ![]() ![]() ![]() |
Thanks folks. Yes I'll check the handbook if I can find it. But yes the main question was how to lift the drivers seat to get at the fuse box. Cheers
Grab the front of the seat base and yank it upwards... My blog - www.anacreinhampshire.blogspot.co.uk
