![]() | Home > Puma (Tdci) > courtesy light |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
The wire runs along under the headlining to the back and then down next to the door. Im guessing you dont have a rear headlining either? The wire will run up the A-post and to a terminal under the front headlining and will stop there if you dont have a head lining. All you have to do is extend this wire.
Pete. |
mike.29 Member Since: 14 May 2012 Location: Scotland Posts: 22 ![]() ![]() ![]() |
Cheers Zinke.
![]() Do you know where about inside the front headlining I should be looking or even the colour of the wire? Don't really want to rip if all down but I suspect I might have to. ![]() 08 2.4 TDCI Defender 90 61 2.25 Petrol 88" Series 2 53 2.00 Petrol 80" Series 1 |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 ![]() |
Check and see if the loom has been taped up above the headlining. I think I have the loom which would do the job in my shed somewhere ?
