![]() | Home > Td5 > Transfer case output seal |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
I did mine a few thousand miles ago, can't remember the socket size and just shoved the seal back in to match the position of the old one. It hasn't started leaking yet!
That is the easy bit though, the handbrake shoes are a pain in the arse. I took mine off to clean the oil off them properly and could not get those securing spring clips back on for love nor money. I believe you can get a proper tool to do it but I had to rely on brute force and voluntary knuckle skin removal! |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6005 ![]() ![]() ![]() |
Thanks. That's what I did last time but was the old seal installed far enough back last time? Who knows! 1999 Defender TD5 110
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1856 ![]() ![]() ![]() |
Is not polishing the area on the drive flange or replacing it as important as position?
If its damaged it will carry on leaking. Keith |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 ![]() ![]() ![]() |
Re. the handbrake. Time for an X-brake?
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Remember to check the breather is clear before you start pulling seals out.
Pete. |
I am not sure what you mean by 'Is not polishing the area on the drive flange or replacing it as important as position?" I agree if it is damaged it will leak. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
I did check the breather by blowing down the pipe (extended breathers fitted) and got some resistance as I released the pressure there was a slight hiss of air. This was the same for front diff & rear diff. So I suspect thats because the air can't escape?
As I had the seal. I had a go at replacing the rear output seal on the transfer case. Removed the prop shaft OK. Then had fun and games removing the cross head screw holding the drum on. I had to break out the impact driver as head was starting to round off using a normal screw driver. Removed the 30mm nut using the buzz gun. Replaced the seal but think the seal is too far in, so may have to do it again! Looking at the flange and where the seal sits, there is a raised bit on the flange, is this where the seal will (should?) site once tightened up / installed correctly? If so, is there a reason why I can't fit the seal to the flange and then put the flange and seal back in place and then tighten the nut etc? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Hi John,
I think if you rely on the flange seating the seal, it will not seat deeply enough and pick up and fail quickly. I bought a recon box years ago for my 100" and asked the guys there about a leak I had on a transfer box, they showed how they polished the surface where the output seal runs to remove the score marks, I bought polished flanges from them and had no leaks on the box from that point on. Don't forget to lube the seal before fitting the flange in, plus IIRC there is a fibre seal in behind the flange somewhere that stops oil working down the splines. Keith |
Hi Ickle
Thanks for the reply. So, ignoring my idea about fitting the seal to the flange. How far in should the seal sit? The felt washer I didn't replace, but will get another one. A polished flange..Sounds fancy.! Does the flange get worn due to rotating within the seal? I did lube the seal before inserting. Once the leak is sorted I will replace the brake shoes, at the mo it pointless due to the leak. So if the flange is worn, one of these would be a good move? http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...3a732ac1af cheers. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Hi John,
The recon guys were spinning the flange in a lathe and polishing with some fine emery cloth, and yes if its scored it will leak. The ebay kit looks superb. IIRC the seal should sit 2mm - 3mm in from the face of the box, I'll try and find my old manual in the morning Keith |
Hi Keith
If you get time to find the manual then that would be ace. For the price of the kit, it will be worth it. cheers john 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Hi John, went through the bits of the manual I downloaded several years ago, I can't find any reference to depth it seats at.
I'll see if I can find the disc tonight. Keith |
Thanks so far for your assistance. 1999 Defender TD5 110
