![]() | Home > Puma (Tdci) > Cost of Air Filter Element |
| CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558
Hi All
I had my Hilux D4D in for a service and noted the diesel smoke has decreased a lot since they exchanged the air filter element. The Puma is smoking ever so slightly when cold so was thinking an element is due by now. Hell's teeth - ZAR600 for new (GBP 49) - is this expensive or can I get one at Ford or Aftermarket? If someone has a part number would be great - Microcat has blocked me as version expired Series III 1973 - going strong |
Thanks Mate.
Will try shop around elsewhere Puma 110 - gone Series III 1973 - going strong |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Not cheap! Got one fitted to mine and for an extra couple of horses and a nice induction noise would recommend it, it's not unlike a K & N you need never buy another;
Linky thingy: http://test.merlinmotorsport.co.uk/p10826/...anguage=en Link may not take you where you need to be, not sure why? Computer biff I am. In search pane punch in 'ITG filter defender.' If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039
Microcat: Try putting the computer time back to a date it was still working.
I have an old version and I can still use it that way. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
| htrowsoc Member Since: 30 May 2009 Location: Zejtun Posts: 11
I changed to a factory fit K&N on my Td5. Just Euro 35 & it will be used over and over again. it imporves slightly the acceleration as well.
Kev |
| All times are GMT |
