![]() | Home > Off Topic > car stopping like its run out of diesel |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
If your motor has been running normally up to now take a quick look at the diesel, if there's a water trap drain some out or crack a feed pipe near the pump and take a look. You could have picked up some watery diesel at a recent fill up, just think garages, wet weather, underground tanks. Might have pulled some diluted diesel through and at motorway speeds it will be damn cold on the fuel lines under the motor.
| Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670
Sounds like water or a part blocked filter to me.
Pete. |
| big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456
yer thats what im thinking 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6726
Moved to
1988 90 Td5 NAS soft top
2015 D90 XS SW |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18033
Waxing?
sorry martin
yes maybe iv found out the fuel filter needs changing anyway so that will be the first move 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
| Maverick Member Since: 08 Mar 2008 Location: Inverurie! Posts: 261
Friend of mine had a 53 plate yaris that would start and run, when you stopped the engine is just wouldn't start again till you re-primed the fuel system. The injector o-rings where cracked so letting air in the system. Doesn't sound like that's what's at fault but could be worth a check if problem persist!
Rebuilt 1996 black/white Defender 90 300 TDi |
| XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632
Don't know how the tanks on these are vented, but it could be something as simple as ice forming in the vent, preventing from getting air in and creating a partial vacuum in the tank. Some cars vent through the keyhole in the fuel cap.
Pete |
considering its only 2 yrs old they will be having it back if there is any more than a fuel filter problem
steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
| Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015
I put it down to driving a Much inferior vehicle.
I had a guy in this last week with exactly the same issue- just changed the fuel filter and he is back to happy motoring. But with him it was because for 6 years he has never gone below 1/4 tank and then his missus let it go to nearly empty The car in front is a Toymota Glyn |
| ThreePointFive Member Since: 03 Jul 2012 Location: UK Posts: 228
Edit: deleted One life - get one.
| yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 714
You haven't filled up at a Morrisons station have you? There appears to be lots of contaminated diesel, I read about it last week in one of the newspapers. I went to a garage here on the island a couple of weeks ago and the mechanic was repairing a new Skoda that had just filled up the diesel looked like used engine oil
