Home > Puma (Tdci) > Heated screen switch
caribcat
2013 Defender 110 Puma 2.2 USW Aintree Green
My light stays on for 3 seconds -assume there is a timer module mounted somewhere? Can anyone shed light on this for me?
Thanks,
Tom
Post #192663 11th Dec 2012 10:26am
iruffell
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
I assume you are talking about front screen? mine stays on for about 5 minutes, back one will stay on until it's switched off
Post #192664 11th Dec 2012 10:29am
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Re: Heated screen switch
Thanks,
Tom
Here's a screen grab of the relevant bit of the book...
Hope it helps..
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #192671 11th Dec 2012 11:05am
jst
should stay on 10-12mins IIRC Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #192684 11th Dec 2012 12:11pm
caribcat
Thanks for the wiring diagram... I assume this is all under the drivers seat, will take a look. I assume the timer has failed completely. Will post the results.
Post #192715 11th Dec 2012 1:54pm
The timer relay (as well as the main screen relay) are under the RH seat.
The timer relay will be deactivated if you press the switch whilst the screen is heating, or if you switch off the engine. Assuming that neither of these is happening, a short ON cycle probably indicates either a defective timer or a loose connection.
Post #192720 11th Dec 2012 2:05pm
caribcat
Relay is clicking away quite happily. Have removed timer and can't read continuity between any of the pins. I assume it's duff?
Post #192772 11th Dec 2012 5:56pm
The timer relay is all-electronic inside (not a conventional relay in any sense of the word) and I suspect that the only easy way to test it is to swap with a known working one.
Post #192781 11th Dec 2012 6:56pm
caribcat
Censored . Don't know anyone with one and the cheapest I can see is about 70 quid! I'll look for a non LR timing relay.
Post #192789 11th Dec 2012 7:32pm
I think Vehicle Wiring Products sells a range of pin-compatible timer relays at sensible prices. I bought one from there for use with my heated mirror upgrade.
Post #192860 11th Dec 2012 11:59pm
Martin
Site Admin
If used is OK they turn up on eBay, like this one: http://www.ebay.co.uk/itm/Range-Rover-Clas...0957438906
Part number PRC6796  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #192866 12th Dec 2012 12:53am
