Home > Puma (Tdci) > battery upgrade
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
battery upgrade
I wish to upgrade my current set-up to run 2 main batteries in parallel situated under pas-seat. This will be in addition to the deep cycle battery in the boot. I will replace the main one I have now with 2 new ones of the same.
I want to do this to have more capacity when winching.
Will the alternator be able o charge all 3 at once???
What batteries is recommended for this set-up?
Post #192286 10th Dec 2012 12:00pm
Marius
Has no one done anything like this?
Post #192872 12th Dec 2012 5:11am
farmerfarrow
United Kingdom 2012 Defender 90 Puma 2.2 X-Tech LE Zambezi Silver
if i see no one get back to you soon, ill ask our farm michanic, shouldnt be much different, but he runs a simular set up to what your suggesting on a discovery, mainly for ac dc converters to run welders etc. will keep an eye on here. see him in a day or two
Post #192948 12th Dec 2012 1:49pm
jst
not on a puma but on a tgv i run 2 Numax in parallel : http://www.tayna.co.uk/Numax-CXV-X-1000-Amp-P7632.html
the leisure bit is immaterial
in fact i run 2 of these in parallel for 12v and 2 in series for 24v on one vehicle
another runs 2 in parallel for 12v and winching as you suggest
i am pretty certain these are the same ones but i havent physcially checked and i know i had 1000CCA. it could be a CXV31MF these: http://www.tayna.co.uk/Numax-Leisure-Batteries-S284-1.html 2nd one down
anything in the CXV range works just find what works for you and space.
do you currently find the two batts you have cant cope with winching or is the bat in the rear not connected to the winch and just runs aux kit? i guess when you currently winch you just winch off the one bat?
alt will cope
adding the extra batts will give you more reserve. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #192949 12th Dec 2012 2:20pm
Marius
Thanks guys,
I mean I knew it should be fine theoretically. My Deep cycle in the boot is for fridges etc...CCA not high enough to winch with. Normally one would run your engine while winching (Extra precaution) but I want to be self sufitient in that area. I still need to fit my winch. Warn9000i. So I want to do the battery thing at the same time.
Post #192978 12th Dec 2012 5:46pm
Not quite the same scenario, but I used to tow a Desert Wolf trailer that was fitted with twin 120 amp leisure batteries. The standard 100 amp alternator on my 300tdi Disco of the time would charge them both and its' own without any issues. Darren
Post #192981 12th Dec 2012 6:03pm
jst
http://www.leisurebatteryshop.co.uk/86Ah-Sealed-Leisure-Battery
may be of use pinched for JSGs thread. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #193011 12th Dec 2012 7:56pm
paulgrs2
United Kingdom 1988 Defender 110 200 Tdi PU Baltic Blue
devon 4x4 battery carrier with starter red top optima and a yellow top leisure battery or equivalant odyssey and a IBS split charge. Fitted loads of this set-up and works well.
Wouldn`t bother with the parell set up direct of the main alternator (keep your starter battery at optimum charge), if anything, split charge between 1 starter and 2 leisures............... or just use a combination of voltage sensitive relays and heavy duty charge relays and a 4 way master switch (alot cheaper way to do it)
Post #193022 12th Dec 2012 8:13pm
jst
how can using heavy duty charge relays or a 4 way master be cheaper than connecting two batts in parallel? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #193025 12th Dec 2012 8:17pm
paulgrs2
was on about between a decent split charge system and a decent home made split system.
Trouble is with parell is the time it takes to recharge, potentially increasing the risk of sulphation/reduced battery life etc. then as 1 battery goes tits up, the system seeks equilibrium and all the juice out the good battery trys to top up the poor one till there both ucked.
Post #193554 14th Dec 2012 7:25pm
mobilecentre
Almost all of the split charge systems are relays which join the batteries in parallel and never actually split the charge Whistle including the Blue Sea systems we sell.
Post #193732 15th Dec 2012 2:26pm
