![]() | Home > Puma (Tdci) > LUBRICANTS FOR SERVICE |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5112 ![]() ![]() ![]() |
There are some posts on here with all the details Mike
My work:
Diffs.: 1. additive Bardahl T&D Fullerene (350 cc) 2. oil CASTROL SAF-XO synthetic GL5 class 80W-90 (fill up to fill-hole more or less 1250 cc) Gearbox: Gearbox type MT82 : 1. additive CPL Gearbox (125cc) 2. additive Bardahl T&D Fullerene (250cc) 3. oil Castrol BOT328 synthetic GL5 (oil 2050 cc) - NB!! remember that the fill hole IT IS NOT THE MAXIMUM LEVEL (like diff. and transfer box) , you need to fill the correct quantity (2,4 liters totally) Transfer box: 1. additive Bardahl T&D Fullerene (250 cc) 2. oil Bardhal T&D SYNTHETIC OIL GL5 75W-90 (fill up to fill-hole ca 2050 cc) After discharged the old oil: - FIRST fill the additives - SECOND add the oil if you want to change the oils WITHOUT add additives: ![]() Click image to enlarge motore = engine cambio = gearbox scatola del riduttore = transfer case differenziale posteriore = Rear diff. differenziale anteriore = front diff The Castrol BOT 130M is superseded by Castrol BOT 328 fully synthetic GL4-GL5 80W-90 oil. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2490 ![]() ![]() ![]() |
Are you sure the BOT is GL-5? I think it is GL-4 and 75W/90. As for the engine oil: Any oil meeting the Ford WSS-M2C913-A Ford WSS-M2C913-B spec. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ............................................................. Earth first. Other planets later Last edited by MK on 30th Nov 2009 12:47am. Edited 1 time in total |
BOT 328 YES!!! (If you want I scan the bottle) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
Do you have a 3D scanner? ![]() ............................................................. Earth first. Other planets later |
Maybe he can copy it so we have free oil. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Pob Member Since: 23 Jan 2009 Location: Midlands Posts: 119 ![]() ![]() ![]() |
Thanks for the brilliant post Dgardel - very helpful
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
LR South Africa use the Castrol BOT 328 GL4 75w90 as well, but I cannot find any information on this oil on the Internet. Even Castrol SA does not know anything about this oil, does anyone have the Technical Data Sheet? On top of this, it costs a fortune: LR dealers - ZAR380/L whereas Castrol BOT 130M - ZAR120/L at various spare shops & Ford dealers. Is Bot328 really 3x better than Bot130M!??? |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 ![]() ![]() ![]() |
after some years ![]() Daniele, can you show me how is the ''bottle'' of this additive? can't find it......... ![]() |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 ![]() ![]() ![]() |
![]() http://www.bardahl.it/lubrificanti_additiv...ive.html#2 Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
Grazie Marco Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
I learned the lesson of our teacher Daniele ! ![]() Thank you Daniele ![]() Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
Grazie Marco !
ho sentito che fa miracoli questo liquido. E dopo che professore Daniele gia usato, penso di provare anche io ![]() |
