![]() | Home > Maintenance & Modifications > Alpine window Dimensions needed please |
| tom1809 Member Since: 28 Nov 2012 Location: suffolk Posts: 15
Hi guys, I have a set of alpine windows from a 110 roof with seals that I want to fit to my 90. I have not yet got a head lining so can't get a measurement of where they should fit. Without upsetting a landrover owner in a car park measurements im wondering if someone can give me a dimension from the rear of the roof to the center of the seal. I have tried to search but couldn't find anything.
Cheers Tom |
| appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630
Now, if you had asked this a month ago, I'd have been able to answer. Unfortunately, I cut the end of the 90 roof I had. I can measure from the front seam to the front edge of the alpine light if thats any good?
Yes that would be very helpful thanks. Should get me close enough, I take it you will go to the edge of the hole as I guess it won't have any windows in it as you cut the back off.
Thanks Tom |
| TR51 Member Since: 17 Apr 2012 Location: Dorset UK Posts: 333
Tom
Let me know if you need any other dimensions for the alpine windows |
Cheers chaps, I have the windows so got most of the measurements i need but just need to know how far along the roof, i don't know if anyone has had the chance to or not get the dimensions.
Thanks Tom Www.thssufolk.co.uk |
I'll try and grab that measurement for you tomorrow
Sorry about this, I've not been up to my yard for a while. As soon as I do, I will get the measurement if TR51 doesn't come up first.
cheers chaps. its not a the top of the list to do but would like to get it done before x mass if i can Www.thssufolk.co.uk
thank you very much, will have a go with it on monday evening, will make the inside a little lighter Www.thssufolk.co.uk
| 238kirk Member Since: 03 Nov 2012 Location: Doncaster Posts: 233
how did you get on with this? did you get them fitted ok? i going to put some in mine and want them in the right place too, ive got the glass and have ordered new seals, i have the measurement supplied above but do you know what the distance is from the gutter to the bottom of the glass? thanks
| All times are GMT |
