Home > Maintenance & Modifications > 16 x 10 modulars
AndrewS
16 x 10 modulars
I have checked but cant find any info.
Does anyone have a pic of a 16 x 10 modular with 285 tyres on ?
What I want to know is will the wheel/tyre stick out past the arch ? 130's have feeling's as well you know Smile
Post #191286 6th Dec 2012 6:48am
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
I've got 15x10" modulars on mine with 33x12.5" tyres on, and they are quite a bit wider than 285's, whilst I was researching what tyres to fit I checked loads of forums and pictures and I'm sure you will be fine, I had to fit extended wheel arches to mine. Don't really help I know.... Confused Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #191299 6th Dec 2012 10:23am
K9F
I too have 15 x 10s with tyres of a 'High Flotation' size of 32 X 11.5. They too protrude from the arches. There are conversion charts (one on here somewhere) and on Google that convert High Flotation sizes to European so you could get an idea what size is best for you.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #191301 6th Dec 2012 10:53am
ickle
285's on 0 offset 8" the tread is just under the arch, with a 0 offset 10" your lock will suffer and rim / sidewall will be well outside the arch.
Keith
Post #191316 6th Dec 2012 2:07pm
Post #191472 7th Dec 2012 7:12am
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Andrew I am currently running 285s on 16 x 8 Mod rim and sit just outside the arch...
Well to be honest in thru land rover fashion they protrude on one side and level on the other ! Whistle
N.
[/img]
Post #191646 7th Dec 2012 5:38pm
