Home > Technical > heated front screen switch
Mattyboy
United Kingdom 2007 Defender 90 Puma 2.4 HT Santorini Black
Afternoon, when I press my rear heated screen switch it clicks, the led lights up and a little light comes on the dash. However when I try the front button, nothing not even a click, am I missing something?
cheers 07 Defender 90 TDCI
98 Defender 90 300 Tdi
Land Rover Freelander
MG B GT
CBR 600
AEC Matador
but no washing machine
Post #191153 5th Dec 2012 3:15pm
jst
does a light come on on the switch itself.
engine must be running. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #191155 5th Dec 2012 3:16pm
Laurie
It won't click, it's like a bellpush.
It just switches a timer on. (8 mins)
Post #191159 5th Dec 2012 3:23pm
The fornt and rear screens work quite differently.
The rear has a latching switch, it stays on until you turn it off.
The front has a momentary switch, which activates a timer relay under the seat and turns the screen on for 10 minutes, after whcih it switches off again autonomously.
To activate the front screen (as JST posted) the engine must be running (an "engine running" signal from the instument panel is one of the inputs to the timer relay).
Post #191160 5th Dec 2012 3:28pm
Mattyboy
thanks, apart from the ice melting on the front screen is there any other way to see if it is working? should the light come on either on the switch or on the dash? 07 Defender 90 TDCI
MG B GT
CBR 600
AEC Matador
Post #191161 5th Dec 2012 3:30pm
Laurie
Boil a kettle inside the Landy.
Post #191165 5th Dec 2012 3:34pm
ericvv
Yes, an orange little light should come on in the switch for the time that the timer keeps it working, or until you push it once again to turn it off. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #191171 5th Dec 2012 3:51pm
It's usually (well, on Td5's anyway) fed from the oil pressure light switch... this gives the "engine running" signal to make the relay click.
Post #191178 5th Dec 2012 4:10pm
The Puma uses an "engine running" signal output from the connector on the back of the instrument panel (Pin 14 on Connector C1040).
Post #191191 5th Dec 2012 5:06pm
ZeDefender
...but it's very weak... Tell someone you love them today because life is short.
Post #191194 5th Dec 2012 5:10pm
if the switch light is weak, open up the switch and adjust the angle of the led indicator light, the switches are only about £7-8 each so alternatively replace the switch
Post #194213 17th Dec 2012 8:18am
JSG
It doesn't seem weak in mine - just as bright as all the other switches. John
2011 Tdci 110 CSW XS
Post #194268 17th Dec 2012 12:08pm
ZeDefender
Next job then... Tell someone you love them today because life is short.
Post #194288 17th Dec 2012 3:14pm
