Home > Tdi > 200tdi 90 h reg
boxer
United Kingdom 1990 Defender 90 200 Tdi HT Coniston Green
200tdi 90 h reg
should i buy a h reg 90 hard top with a 200tdi engine has done 130,000mile its had a new clutch,gearbox,exhaust,wheel spacers,diff gaurds,rock sliders,chassis is good, small amount of corrosion in corners of the bulkhead,the guy wants £2500 only problem is reverse the new gearbox worked fine then reverse got harder to select now it wont go in at all could be a quick fix?.what do you guys think regards price and the reverse issue.
Post #190400 2nd Dec 2012 9:35pm
GUM97
Well if it suits your needs, and you can afford it, and you want it, then buy it. It seems a decent price, but the gearbox would probably need repair by a specialist, not really a DIY job, An engine to TDi for!
Post #190404 2nd Dec 2012 9:43pm
ickle
Would be worth doing a search, I can remember something about the indent springs and bearings messing up but being repairable in heh car on a LT77 box.
Also they run ATF, yes ATF in the gearbox not gear oil, this can lead to non changing gears.
Box was same / same family as the TR7, jaguar etc.
Regards
Keith
Post #190424 2nd Dec 2012 10:47pm
boxer
cheers guys, think i will give this one a miss but thanks for the advice
Post #190908 4th Dec 2012 6:29pm
