Home > Maintenance & Modifications > Can you change the side window glass?
Killer90
Site Sponsor
I see land rover sell a part for the 1 piece sliding glass on its own- part number: cpb000220, can you just change the glass i take it? if so how hard is it to do cheers Thumbs Up
Its going into the side windows on a puma 110 csw xs so are the later type windows bonded in Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #190041 1st Dec 2012 2:55pm
Tiger
You need to take the whole window out first.
You can the 'split' the frame, countersunk screws from memory and slide the glass out.
Mine was riveted so drilled the rivets out to release the window, if it's bonded in the f@&k knows how you do it.
Post #190051 1st Dec 2012 4:32pm
Killer90
Site Sponsor
Thumbs Up cheers mate i can see the counter sunk screws two on each side aint there Thumbs Up pulling it is a pain still not out Big Cry CSK Automotive
Post #190069 1st Dec 2012 5:50pm
Jim_Bean
Did you manage to replace the sliding window glass on your Puma? I would like to do the same on my 2013 110 with the bonded windows.
Post #340057 23rd Jun 2014 12:05pm
Killer90
Site Sponsor
Sure did fella, you do have to remove the windows which is a bit of a job. I use cheese wire now and a long bladed knife to cut the bond when i remove to fit panoramics Thumbs Up Doing one today funnily enough Mr. Green CSK Automotive
Post #340062 23rd Jun 2014 12:28pm
