![]() | Home > Td5 > Bulkhead Grommets |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
I just taped mine up, but I'd be interested in some grommets too. The problem will be that the genuine grommets have an aperture in them for the pipes, so they won't really solve the problem. Maybe just some rubber bungs is the best solution. 2005 Td5 | 90 Station Wagon | Tonga Green
Measure the hole and you could always stick a 'skin top' gland in the hole with a cut piece of cable running through it. Any future modifications just slacken it off and remove the piece of cable and you've a ready prepared gland to run what ever you wish through it.
![]() ![]() Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 26th Nov 2012 9:33pm. Edited 2 times in total |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20915 ![]() ![]() |
What K9F mentions is a good solution. They are great for that sort of thing.. ___\⭐️Lone|Star|State/___
____\We|Will|Win/___[/size] ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
brisca33 Member Since: 17 Sep 2012 Location: Knutsford,Cheshire. Posts: 3 ![]() ![]() ![]() |
I also found missing grommets/wet behind mat when fitting a noise killer kit to my TD5.Asked at main dealers(Guy Salmon)but they could only locate the Defender grommet page which said the 2"-50mm one is not available so i ended up getting a series of blanking grommets off E-bay,that was one leak sorted,you've just got to love them.
