![]() | Home > Maintenance & Modifications > Auto and tdci |
| ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2964
ashcroft transmissions
| sense of adventure Member Since: 11 Nov 2011 Location: warwickshire Posts: 147
Yes, done it, but the puma doesn't lend itself to an auto aswell as a td5.
| big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456
it might do if i can get my hands on a 6 speed auto from the ford ranger steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Correct!
| bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189
Can I ask why you say that? BM52 |
Due to the extreme low down torque and the unwillingness to rev very well of the puma , it all becomes very jerky.
Ask to drive one if your interested, Ashcroft or Berkshire have one. A project in the new year is a 8 speed unit on a puma with paddles, just need the customer to decide exactly what he wants, it will probably be a 3.2 now tho. |
Good luck finding a engine 2015 2.2 tdci hardtop xs
Not an issue at all, he has 2 in transits, one only does 50miles a week, I will then replace with a 2.4 tdci. |
| littlepow Member Since: 13 Oct 2012 Location: North Yorkshire Posts: 11
Ah, should have added it will be on the back of a Td5 engine - just like (and want) a Tdci dashboard and heater. If I knew what I was doing - I would be scared!
Cool who you going to get to make it run ? 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
| JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758
So in effect are you asking if you could put a tdci dash in to a td5? In theory yes if you use the tdci bulkhead, heater etc. The auto console will be the easy bit of the conversion |
| landyman37 Member Since: 22 Jan 2012 Location: west midlands Posts: 156 |
The hard part I have found is trying to get the dash to marry up with the engine got it all running apart from the temp gauge and the rev counter as they work of CAN wires. I am still trying to sort this out. Looking for ideas to over come this Phil |
Have started to map out the wiring for a Td5 and a Tdci to see which wires will need to be connected - wiring diagrams are fun! If I knew what I was doing - I would be scared! |
Hi been there got it running but the temp gauge is beating me at the moment
Phil |
