![]() | Home > Maintenance & Modifications > X-Tech Leak |
| willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789
Went out today in the torrential rain, looked in the back and it was full of water. Can't be coming up through the tie downs or wheelarches and I had sealed the tub to side panels so thought at first it must be the roof. Anyway I removed the two rear speaker trims and found it sodden, all wiring and speakers soaked through
You can see the water marks here
Looks like its getting sucked up the capping outside and into the rear. You can just see in the corner there is quite a gap. You can see how far the capping is away from the body.
Sealed up outside and in with gutter sealant On the other side you can see there is a hole under the coloured wiring, normally a connector block mounts into this.
Here you can see where I filled up under the capping Original Member Pie n Pea Club.
110 HCPU Tipper |
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328
THey all do that sir
Mine has not leaked in this rain |
| NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972
It's indoors Ken
54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
| Andy Jeff Member Since: 11 Nov 2012 Location: Suffolk, UK. Posts: 143
The only manufacturer to do a water ingress manual
Andy. |
Argh but it was outside today as the Lambo was on the ramp again
Putting the Mud Tyres back on Ken
110 HCPU Tipper |
No winters actually
| TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752
Nor mine Main Brian James Trailer Dealer for South West UK |
| walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2713
Mine did , hence it was chopped in for a D3. No more leaks for me
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
| BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785
that you can see at least 2011MY 110 XS USW Black |
| All times are GMT |
