![]() | Home > Technical > Anyone run a Husky EW8000 winch? |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
What does it look like
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6216 ![]() ![]() ![]() |
It's one of these:
![]() Mine is missing the RH plastic piece, and that's what was confusing me.... easily done ![]() |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1861 ![]() ![]() ![]() |
Add a 6hp Bowmotor before you fit it, really worth while.
Also did you sort your washer motor? Keith |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2703 ![]() ![]() |
I've got a cheap set of plastics for it. Will cost you though. Will have to work out how many hobnobs it'll cost ya
![]() ![]() 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 ![]() ![]() ![]() |
i do..
box ![]() (this is original camel trophy spec, silica gel pockets included) more on install: http://www.defender2.net/forum/topic7878-45.html Don't forget your 4th wire. Earth going from husky motor underside (the small bolt in the middle) to chassis or directly to battery. Depending on how high the husky is on the bumper mounting points you'll have to connect the cable or between bumper and motor (a pain when it comes loose/checking-inspecting and needs to be done before you bolt down the husky) or if your motor rests on the bumper from underneath the bumper with a bolt going through bumper into motor. (make sure the motor is 100% in contact with the bumper, if not you risk deforming it when tightening this bolt!) oh and clearly,if going the second route, measure and double check your bolt length.... ![]() :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
@ ickle: its got a bowmotor2 on it already. and no, not done anything more about the washer motor yet.... next job on the list
![]() @ tatra805: nice job that, think i'll do the same. Where abouts is that box mounted, up under the wing somewhere? what about the remote socket? @ walfy: I see they do huge tubes of jaffa cakes now too.....could tempt you with one of those? ![]() ![]() |
Hob nobs, Curly Wurlys or Jaffa cakes. I'm easy
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 675 ![]() ![]() |
Jim, fit an Albright and then you don't have to use a waterproof box and its easy to moun n inner wing behind headlight.
Cheers Steve |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17980 ![]() ![]() ![]() |
Yes, several (one on the Puma and two on the Series 1). Excellent winch! Latest incarnations use Albright solenoids anyway, but if the early type it is a worthwhile upgrade (it's still worth protecting the solendoids though). Nothing wrong with the standard motor. If you want an industrial quality electric winch you can't do better than one of these. |
I have Jamie's albright in my garage so I'm assuming it will be fitted now
Cheers all
Yes, will have an albrite or durite equivalent, mounted in an IP65 box I reckon.... something tells me I might have one lying around at work... and some glands ![]() ![]() |
Mine is mounted on a Mantec bumper and sits on 4 spacers so the wires can run underneath.
Ah, interesting, as my bumper has a couple of "rails", about inch or so wide and 3/4" tall.... reckon the cables would easilt fit under them.
Can crimp some up the perefect length to fit under the wing to the solenoid box. |
My solenoid s are on the right what you have missing 3wires come out under the winch to the motor then ran the battery cables along chassis that Brendan made up for me to a isolater job done
