Home > My Defender > 110 X-Tech Grey Update
Page 5 of 15 <123 456 ... 131415>
Focal Tweeters in Mr. Green
Still trying to make time for proper fitment of the rear carpets (Winter Tyre programme takes president)
More later
Post #183227 8th Nov 2012 5:49pm
Pictures Ken Question Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #183229 8th Nov 2012 5:54pm
Has Killer been at your centre dash ?
Post #183249 8th Nov 2012 6:25pm
Killer90
Site Sponsor
come standard in a xtech Thumbs Up much like the Ice Steve Cool CSK Automotive
www.cskautomotive.co.uk
Post #183253 8th Nov 2012 6:32pm
Mr B
ken wrote:
Test Fit
Hey Ken,
Great looking truck you have - can I ask where you got the rear carpet from? Presume it's not stock landrover as it runs up the inside panels. Looks great.
Thanks
Nath
Post #183346 8th Nov 2012 11:06pm
Side Panels (Where windows could be) tge-defendertrims with Dynamat behind
Floor & Wheel boxes Dynamat Extreme then OEM carpets
Lower side panels Acoustic carpet
Post #183360 9th Nov 2012 5:33am
are you sure Chris?, the pics at the beginning of the thread looks like the dash is black
Post #183381 9th Nov 2012 8:29am
Just the Flash the Centre is Grey (Standard XTech)
Post #183398 9th Nov 2012 9:21am
Well the test fit for the ICE has gone well
Fitting the KIV-700 HU with all the extra RCA’s was fun and it’s going to have to come out again for the light bar install
As per the old Utility the rear cargo area has be sound proofed a bit different this time as I reverted back to the trusted Dynamat (seems to be making a comeback)
The method I employed was the floor and rear wheel arches are fully matted and the side panels (where the CW’s have glass) have 12 x 12 panels applied (enough to stiffen the panel)
The sides and Floor are now trimmed in sound deadening carpet
The OEM 10cm has at the front Focal 100KRS with the tweeters being replaced as part of the kit and the crossover being hidden behind the dash (gotta love black tack)
The rear apertures currently have “theloudest.co.uk” 300w 10cm co-axail units (these will be replaced with Focals in time
Also in the Back is a Focal Active Bomb & an Alpine 2ch Amp to Power the Rear RCA 6x9 TL2691’s in separate enclosures
Each Amp has a separate power feed
The initial set up sounds good will improve with a Focal upgrade
Now to route cables neatly
A point to note correct sound proofing will keep the sound in unlike the Essex Gary boys corsa’s
Pics when completed Thumbs Up
Post #186793 21st Nov 2012 7:03am
You're getting good at these write ups Ken Thumbs Up
Two questions, do you rate the Focal 10cm speakers over the Loudness ones as I'm about to sort the front out and which brand / supplier did you use for the acoustic carpet please ?
Post #186794 21st Nov 2012 7:19am
NoDo$h
I had a sneak audition yesterday, halfway through the installation,and it sounds and looks gooooood! Cool
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #186798 21st Nov 2012 7:46am
Matt
Focal gives a Crisp Hi and Mid so great if you supplement with a Sub
if no Sub then Loudest are suitable
Carpet from Car Audio Direct no real reason other than it was in stock Thumbs Up
Post #186799 21st Nov 2012 7:55am
Thanks Ken,
At the 'back end' I was thinking of the Loudness 6x9 Component speakers (TL2691) run from one of their 4 channel amps bridged (TL2904) with a Kenwood KSC SW01 150watt 'powered sub' - at the front end I was going to go for the Loudness 4" components but now I'm undecided ...
Now you've seen the rest of my proposed set up would you still go for the Focal at the front ?
Post #186819 21st Nov 2012 9:31am
TBH The Focal Tweeters at the front with the 10cm speakers make it for me
But sound stages are very personal I feel
Post #186822 21st Nov 2012 9:51am
Thanks Ken Thumbs Up
Post #186845 21st Nov 2012 11:29am
