Home > Td5 > TD5 Fuel pressure
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
TD5 Fuel pressure
Hi,
I have made a fuel pressure gauge after using donated pipes from and old PRV. It works very well and I am now in need of some information what I should see for a healthy fuel system.
1st I measured the pressure before the PRV which was a little over 4 bar once pressurised.
2nd I measured the pressure as it came out of the fuel cooler which was .5 bar.
I have found a little info. on the internet where they suggest the 1st reading should be 7 bar approx and the 2nd reading be 4 bar.
Does anybody have any experience with measuring the pressures and what to expect? Eventually I will lengthen the gauge pipe for readings while under load.
Thanks,
Steve
Post #81935 25th Jul 2011 10:31pm
stu-pid
United Kingdom 1999 Defender 110 Td5 HT Bonatti Grey
The pressure after the fuel has gone through the pressure regulator should be a fairly consistent 4 bar even at high revs, the pressure before the regulator direct from the pump is normally around 7 bar. No idea about the return pressure through the cooler though.
Post #96421 26th Oct 2011 7:16pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
How do you know the gauge is anything like accurate? Was it taken from a calibrated instrument? Often things like that can be 'indicative' at best...
Post #96428 26th Oct 2011 7:46pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
""The two stage pump comprises a high and low pressure stage. The low pressure stage draws fuel from the swirl
pot through a filter. The low pressure stage pumps fluid at a pressure of 0.75 bar (10.9 lbf.in) and a flow of 30
litres/hour (8 US Gallons/hour) to the fuel filter. A proportion of the fuel from the low pressure stage also passes,
via a restrictor, through a jet pump which keeps fuel circulating in the swirl pot. The high pressure stage draws the
low pressure fuel from the fuel filter and pressurises it to a pressure of 4.0 bar (58 lbf.in). The pressurised fuel is
then passed from the pump to the injectors at a flow of 180 litres/hour (47.6 US Gallons/hour). A fuel pressure
regulator is located at the rear of the engine and ensures that the delivery pressure remains at 4.0 bar (58 lbf.in)
by controlling the amount of fuel returning to the fuel tank.
Post #96469 26th Oct 2011 9:36pm
Steve B
Hi Zinke,
Thanks for the reply, I completely missed it until looking for my post to reply to another Thumbs Up
Steve
Post #186485 19th Nov 2012 11:13pm
AlexLandy10
United Kingdom 1999 Defender 90 Td5 HT Zermatt Silver
that looks just like the bit of kit i need to test my fuel pressure, would you be willing to lend it or make another one for some shiny coins, its a last straw attempt to make my td5 sound like it should instead of a tractor. If at first you don't succeed, hit it harder or get someone else to do it.
Post #186663 20th Nov 2012 7:49pm
wslr
Alex - If you PM me I can probably have one made up for you if you like. Would be around the £80 mark though.
Post #186725 20th Nov 2012 9:48pm
Steve B
Hi Alex,
Your welcome to use it if you are passing. Have you kept your old prv block for the donor pipes?
Wslr's offer sounds good, by the time you have all the parts and your time...
Steve
Post #187057 21st Nov 2012 10:54pm
AlexLandy10
Hi, thanks for the replies, i haven't got the old regulator as it was returned to the supplier for them to return to the manufacturer, Ill let you know if im passing Steve B and WSLR i might be giving you a shout if i decide to get a pressure gauge made, a local Landy garage have said that they have a kit for testing the pressure so goin to give them a try first, they have said that i can take my regulator off and check the filter behind and just fit a new gasket and o ring, is this a wise move or not? If at first you don't succeed, hit it harder or get someone else to do it.
Post #189195 28th Nov 2012 12:57pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Off topic but what other exciting things have you got going on under the bonnet? Is that a catch tank of some sort on the bulkhead?
Post #189285 28th Nov 2012 7:12pm
Steve B
Yes. Just a cheap one of ebay.
Just air and diesel going into my engine, no egr or blow by. The only benefit really is no oil build up in the intercooler. Emissions still ok.
Steve
Post #189302 28th Nov 2012 8:10pm
me@td5.org
I've been looking at a few mods to reduce the oil mist going into the breather and also maybe fitting a catch tank or a filter with an oil return.
Post #189313 28th Nov 2012 8:33pm
Steve B
This was my thoughts too, also should an engine problem arise it should reduce the chance of running on its own oil?
One point, if you do it make sure the pipes and tank breath freely. Any restrictions and the crank case pressure will be too high and seals/ gaskets will leak.
Steve
Post #189326 28th Nov 2012 9:00pm
excossack
Sorry to HiJack Slightly
/HiJack On
So the oil breather catchtank is connected as follows:
Rocker breather hose goes into a catch tank, then the oulet of the catch tank then reconnects to the original breather pipe and then any engine oil gets caught in the tank and does not (or reduced) enter into the Intercooler which in turn does not get into the inlet side and dragged through the engine?
/HiJack Off 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #189476 29th Nov 2012 12:52pm
Steve B
Yes that's right, or you can just vent.
Post #189686 29th Nov 2012 11:11pm
