![]() | Home > Tdi > HELP Problem engine 2.2 |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Usual is the turbo/intercooler hoses coming off or splitting, use a mirror to inspect under the hoses. QRZ 2e0vpf
Aäron Member Since: 26 Oct 2010 Location: Sedella Posts: 27 ![]() ![]() |
i drove white it for 40 minutes, is it harmful for the engine ?
duble post
It won't cause any real damage if it is a hose. Best to give them a good checking. QRZ 2e0vpf
Michael Brindley Member Since: 07 May 2008 Location: stoke-on-trent Posts: 85 ![]() ![]() ![]() |
mine went after 2 months slit right down inch long also lr assist couldn't find fault but diagnosed mass air flow fault on computer had to-drive 100 miles to dealers in limp mode but when they entered fault code there was a recall for intercooler hose to be changed for longer tube so they did this as well.Had problems from day 1 thought it was noisey but was told it was due to increased turbo boost by lr assist.Two months later same noise different lr assist guy said thats noisey.
