Home > Off Topic > Help needed with Audio set up - |
v40mav Member Since: 25 Aug 2008 Location: UK Posts: 206 |
I'm looking for advice from some of the experts on here
It that time of year again to get the Santa Sleigh ready for the Round Table collections. Last year I installed a complete new audio set up and Amp for the sleigh - comprising Stereo head unit to play the CD's - BASIC CD player Mutant MT4001r Amp to boost the power and sound to the Vibe Q369 speakers - Waterproof - Sony Waterproof front speakers Amp And all electrics in a waterproof case - powered from Aux Battery in my Disco 3 Click image to enlarge It all worked well but running with a CD was a pain - and the thought this year was to just use an iPod - It's been suggested to do away with the head unit and link the ipod direct to the AMP ????? I've mocked the set up tonight and connected it all up with the exception of the "blue wire" that came from the head unit to the RMT connector. See pic below from last year So far there is no life in the AMP Will the AMP power up without the RMT connection ? ( Set up as now as TEST ) Click image to enlarge PIC before dismantle last year Click image to enlarge If Yes - Then It appears there is another issue - I'm just taking a ground from the battery Neg - should that be ok to test ? On the Sleigh this is grounded to the chassis If it needs the RMT - any idea what this input is - is it a Voltage input that can be sourced elsewhere - ? Will the input from an Ipod straight to the AMP be a workable solution ?????? If not then we can seek to find another head unit to plug the ipod to that but if possible it would be good to bypass that - and I'd prefer not to have to invest in a new Stereo Any suggestions welcome Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Defender 110 County SW Disco 3 HSE Freelander 2 HSE - SOLD going back to a car www.lothian4x4response.org |
19th Nov 2012 10:46pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
the man to ask is CustomSteve he will be along shortly CSK Automotive
www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
19th Nov 2012 10:48pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19635 |
As an added note I think the easiest way around for you would be to get a cheap second hand fully working HU from say E-bay and use that. All it will need to use an iPod is an Aux in jack and that's all. This way you'll have the Blue RMT cable as well all ready to go. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
19th Nov 2012 11:01pm |
Kev stephenson Member Since: 27 Feb 2012 Location: Huddersfield Posts: 56 |
Run a wire from the 12v live next to the RMT via a switch to the RMT connection. As said all it is is the switch for the amp. No need to fuse as the main live connection should already be fused.
If you want it really easy then don't use a switch just a wire with a connector at easch end and disconnect it as in the first picture when you have finished. 2005 110 TD5 XS running Alive Stage 1 and a bit and other toys 1996 130 300TDi chip truck for tree surgery business |
20th Nov 2012 1:22pm |
Also take care to disconnect the battery when moving live cables otherwise it's very easy to short it by accident just touching ground -
Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
20th Nov 2012 1:48pm |
Thanks for the responses guys -
I tried quickly this morning before reading for work and nothing Now I was using 2 12v 7.5ah slab batteries - These were fully charged and both @12.5v on the multimeter. I used the second battery to provide the 12v ( Blue ) feed. I've a lot of work to do tonight ( WORK as employer ) before I can try again - Will keep you posted - Thanks Hugh Defender 110 County SW Disco 3 HSE Freelander 2 HSE - SOLD going back to a car www.lothian4x4response.org |
20th Nov 2012 7:28pm |
