![]() | Home > Camping, Caravanning and Holidays > Afrispoor / Globemaster Fittting Out |
| iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343
I use these on all my camping equipment http://www.bes.co.uk/product/70~LPG~1751~1...ling-.html Saves having to have a regulator on everything and I've also made up a Y adapter so that I can have the stove & BBQ running off the same gas bottle at the same time. ![]() |
| chopcat Member Since: 11 Sep 2012 Location: Pembrokeshire Posts: 414
I have also found these people who do panel mount lab fittings which will do for the gas http://www.coleparmer.co.uk/Product/Metal_...U-31403-72 and for the water Koolance water fittings used in PC cooling. http://www.specialtech.co.uk/spshop/custom...11761.html Am still looking though. CC |
The kitchen build is going along well with the last finishing coats being applied so more pictures soon.
In the mean time the sink has arrived and thoughts have turned to the pull out sink unit. Here are some sketchup images of the various folding bits and you can see the idea of the burner flipping out of the sink for that morning cup of coffee. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge I am probably going to built in a hardwood frame with phenolic laminate top. or possibly stainless / ali depending upon how i feel at the time. I have a bit more ash to use up so we shall see. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
Today the old heavy pine kitchen came out and the new carcass went in.
Just like that .... Click image to enlarge Click image to enlarge Then the drawers which are made from the bodged ones in cherry from the bedroom side as they are smaller Click image to enlarge Click image to enlarge Then attention turned to the pull out sink combo. This is going to be really tight fitting this in but i think will greatly enhance the useability of this space. First off i made a recessed base to sit in between the runners as the sink needs to sit down as low as it can possibly go. Click image to enlarge this was done in ash, domino jointed together for strength. the plan is now to mock up the top unit in ply to see how it all goes together Click image to enlarge what i have found is that the sink needs to be altered to get the tap connection accessible. here are the quick release water fittings that i am using - originally made for cooling computers Click image to enlarge over the weekend i will have a test install into the trailer and see what needs to be altered. the mock up has come up with one idea. there is a large storage area, where the sink isn't wich is just the right size for the instant water heater / shower unit. So the current plan is to create a fold up water heater unit, or possibly one that hangs on the open door so that everything is all together in one place. see you all next time CC Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
here is the mock up.
the final version will be in ply with a laminate, as I have never tried laminating so now would be a good time to learn Click image to enlarge Click image to enlarge and here is the condiment carrier in the early stages Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
| d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044
looks really good work there, would look nice in my lounge!
Almost too good to use, like the look of the sink and burner DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
| jasong4110 Member Since: 18 Oct 2009 Location: Henley On Thames Posts: 268
Looks really good, how is the water heater going to be mounted? You woodwork looks far superior to mine however I did end up changing the cooker unit from wood to Aluminium as I found that it started to swell when it got wet from the sink etc and as I just used friction to hold it in it became difficult to open.
Jason. |
| nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546
VERY NICE!!!
what brand is the stove / sink combination? WANTED: SII or SIII in max 1.5k |
The sink is from a company called Can. You can get from caravan suppliers although it isnot cheap. And I had to alter a fair bit. But on the plus side hopefully it will fit.
I think I will hand the water heater on the end. I had an idea of flipping it up on the lid bit but that got a bit too close to the tent fit comfort. So it will be stored in the pull out drawer, taken out and connected when needed. I plan to have the sink and gas ring plumbed in fir cold and then plus in the hot supply wen camped. That will allow the enroute coffee break without much fuss. Cc |
| Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226
Love following this thread chopcat! Great work, really tidy. Look forward to seeing further developments in due course. 2005 Td5 | 90 Station Wagon | Tonga Green
Well no kitchen area will be complete without a pull out bar.
This is going to replace the metal box over the sink unit. The idea will be to have a double extension pull out unit with cups and glasses in font and the cocktail shaker behind. Here it is closed Click image to enlarge then one section pulls out Click image to enlarge then the second Click image to enlarge of course it will clash with the gas burner, but then the metal drawer does that at the moment CC Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
today the sink unit goes together.
after filling screw holes on the base section I had my first go a laminating here is the base sanded down Click image to enlarge and a big roll of laminate from polyrey Click image to enlarge chopped roughly to size with the track saw that is then stuck on with evostick which will hopefully prove man enough for the task and trimmed with a flush trim bit Click image to enlarge i have used moisture resistant mdf for the top surface and have edged with ash Click image to enlarge the sink is a tight squeeze Click image to enlarge hopefully i can laminate some more tomorrow keep watching cc Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
with the carcass put together it is time to laminate up the top.
here are three shots showing the end which is glued up with evostik, left to dry to the touch. hen using a couple of dowels you can position the laminate before starting to firmly stick it using a metal roller to make sure it is fully adhered. Click image to enlarge Click image to enlarge Click image to enlarge finally the trim router is used to clean up the edges Then on to getting it into the trailer. Click image to enlarge Click image to enlarge there was one cock up which i will tell you about once i get the plumbing done Click image to enlarge cc Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
| Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808
Was this really posted on the 16th December!!??
I have been wathching this with interest as I am doing a similar unit to fit in the back of the 110 DC, all be it a LOT less involved due to the comparable skill levels! I ordered my laminate yesterday so have picked up a good tip about the dowel. BTW...Are those Veritas planes in the background? If so.....nice |
| All times are GMT |
