Home > Puma (Tdci) > Remove N/S Outer Wing
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
I'm trying to remove the N/S outer wing so I can place a Webasto in the space next to the heater air intake. I have all but three of the bolts out, the last three are tucked away behind the heater air intake, which I can't figure out how to shift.
I've tried various things but 2 hours later there has been no major progress Twisted Evil Twisted Evil
All help gratefully received! Thumbs Up
P.s - I have done a search, but couldn't find the answer...
Post #185620 16th Nov 2012 4:59pm
Happyoldgit
You've removed the plastic wheel arch right? Steve.
http://forums.lr4x4.com
Post #185631 16th Nov 2012 5:27pm
Phoenix90
When you say the plastic arch do you mean the inner plastic arch or the eyebrow? I have the eyebrow out, but not the inner arch. I was trying to do it whilst leaving that in place if at all possible...
Post #185652 16th Nov 2012 6:22pm
I wouldn't be surprised if you don't have to remove the inner arch plastic too for access. Probably not what you want to hear but I wouldn't be surprised if it doesn't have to come off. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #185653 16th Nov 2012 6:29pm
Eduardo
Phoenix90
Take a look in the Workshop manual (you can get it from internet) under the section Body & Paint 501.02: Front End Body panels.
All the procedure is there.
Cheers Eduardo
Post #185654 16th Nov 2012 6:29pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Are you trying to remove the whole outer wing or just the outer wing skin ?
If the former then it's normally a lot easier to just remove the whole wing, inner and outer in a single lump. The inner wing is held onto the chassis in very few places compared to how many bolts hold the inner wing to the outer.
If it's just the outer side wing skin you're removing then it's usually just a case of finding the correct size/combination of ratchet extensions. The bolts holding the wing skin to the bulkhead are easiest to get to through the gap left when you remove the wheel arch flare, again using a combination of extension bars on a ratchet. Some of those bolts (all but the top one IIRC) have slotted holes so only need to be loosened a few turns. The plastic heater duct that goes from the top of the wing to the heater intake can be removed giving easier access. http://www.yorkshireoffroadclub.net/
Post #185736 17th Nov 2012 12:14am
have a word with Cobs, he's got some great instructions with photos doing exactly that ... and fitting a webasto.
Post #185751 17th Nov 2012 9:12am
Phoenix90
Just the wing skin, if I could figure out how to get the heater duct out as you mention above i'd be sorted as that is blocking the last 3 bolts but I can't figure out how to get it to budge. I can't see where it is fixed down...
Thanks Steve, i've got cobs instructions but i'm going for the other wind where mobile centre install them and the heater duct isn't a problem, still great write up though Thumbs Up
I'm going to head back out the garage and hope it will have all become clear overnight!
Post #185753 17th Nov 2012 9:34am
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Can't really offer any constructive advice on the nearside wing but initially I did go through the same thought process on the offside and eventually concluded that the only way was to bite the bullet and take the inner wing off as well. Key thing is not to do it if you're in a hurry, patience, plenty of tea and long extension bars for the sockets.
Post #185761 17th Nov 2012 10:20am
Phoenix90
Solved, and I have to admit it probably should have been obvious Embarassed
Where the air intake is for the heater there are two screws that hold the air ducting to the wing, however, if you have chequer plate on the wings you may need to remove this to reveal the screws Whistle
Once the screw are removed the air ducting can the pushed to one side revealing just enough room to squeeze a hand in with a ratchet spanner and undo the last 3 bolts...
Thanks for various suggestions Thumbs Up
Post #185783 17th Nov 2012 11:35am
davew
It's not really fixed down as such. If you remove the grill on the top of the wing, underneath the grill there are 2 screws that fix the duct to the underside of the wing that are covered by te grill. Undo those and it should come loose. After that you'll have to remove the wing support/strengthening bracket that goes from the outer to inner wing and it's just a case of manoeuvring the duct out. It's a bit of a PITA but it will come out.
If you have aircon that will make the job more difficult and you may find that just loosening it allows you to get enough access without removing it - being able to get your hand in through the top of the wing makes life a lot easier in itself. http://www.yorkshireoffroadclub.net/
Post #185785 17th Nov 2012 11:40am
mk1collector
I was hoping someone would come up with an easy option for doing this job as someone ran into the front of my 110 the other week so I've decided to put both outer skins on. Could the OP post up any insights when he's finished the job please.
Ray
Post #185786 17th Nov 2012 11:40am
While it's apart, why not fit a BBUS for the alarm (unless there's already on tucked away behind the plate)?
Post #185955 17th Nov 2012 9:50pm
Phoenix90
blackwolf wrote:
While it's apart, why not fit a BBUS for the alarm?
A what now Question
Post #185956 17th Nov 2012 9:52pm
Battery Backed Alarm Sounder.
Post #185957 17th Nov 2012 9:53pm
