![]() | Home > Maintenance & Modifications > Anyone fitted a sub under the centre cubby box? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
Under the cubby box is possible with some work but under the seat you've got no chance unless you mean in the actual seat box. (I wouldn't recommend it anyway)
No pictures I'm afraid from me as I have a different set up with mine. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
The SVX has the sub under the cubby as standard fit from LR. Have a search on here as somone put some pics up a while back of the set up.
Pete |
AlpenAndes Member Since: 20 May 2011 Location: Currently Chile Posts: 128 ![]() ![]() ![]() |
Hi,
I installed mine even under the cubby under box, depending on the size and shape of the sub, mine is round, it needs some work. It lifted the cubby box in a way that it is in the same height than the window sill, my ellbows rest in the same height now. Carefull to still have space for the gear lever. Unfortunately I am far away from my car to take some pics. BR Oskar |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
put my sub behind the cubby box. see my gallery for pics BM52
J8GHX Member Since: 22 May 2012 Location: Hampshire Posts: 154 ![]() ![]() ![]() |
Just like BM52, I fitted mine behind the cubby box.
It really does transform the audio system from awful to more than acceptable for less than £200! This pic is from my old 90XS, but I've got exactly the same in my new one (its that good!) ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Previously..... Quite a few! I really am a sucker for them! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17877 ![]() ![]() ![]() |
I fitted mine under the cubby, raising the cubby about 3" to 4" in the process and levelling it. It is now a more comfortable height when driving. I also had to move it back a bit to clear the gear lever, but in doing so had to be careful not to lose the ability to tip the second row seats forward (mine is a 110 DC), something that wouldn't of course be an issue on a 90. It wouldn't have been possible to mount the sub on the rear of the cubby without losing this ability.
DarrenJ Member Since: 07 May 2012 Location: North Beds Posts: 312 ![]() ![]() ![]() |
I don't suppose you have a picture of what it now looks like do you? Also how much clearance did you leave between the top of the sub and the bottom of the cubby? Thanks Darren |
![]() ![]() ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
I agree, looks good with the white exposed, mine is Stornaway too and it's a cracking colour ![]() |
No pics I am afraid, and it isn't easy to see with the seats in since the unit I made which sits under the cubby is slimmer than the seats. There's about 1" clearance between the top of the sub and he bottom of the cubby. I actually need to take it out again to cover the new bit in black vinyl to match the cubby, since I didn't have any when I made it. I'll see if I can get some pics when I do. From outside looking in through the window you really wouldn't know it was there. |
Mine is in a cubby hole I installed under the passenger seat (LHD)
![]() Click image to enlarge This one, as recommended by Steve ![]() ![]() Click image to enlarge Sounds ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() But shout it at them in German because life is also terrifying and confusing... |
Matt - how have you got it mounted just inside of with the grille facing out the hole? Can't quite work out where you've put it.
Thus:
![]() Click image to enlarge Wiring goes up into the seatbox so you can pull it out to admire it: ![]() Click image to enlarge Really must tidy up those tatty carpet edges - wifey wears vicious boots ![]() Any ideas? About the edges, not the wife :roll: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() But shout it at them in German because life is also terrifying and confusing... |
Err carpet her boots.
![]() No seriously tidy up with a stanley knife blade then I'd glue it down either that or buy some alu strip or something and make it a bit more fancy and rivet it on. With the size of that thing I still don't know why you didn't put it somewhere else Matt rather than chopping the seat box out. Must have had vandalism in mind. ![]() ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
