Home > Td5 > MAF sensor
TD5_90
United Kingdom 1999 Defender 90 Td5 CSW Epsom Green
MAF sensor
Hi
Is a Siemens vdo MAF a genuine part? One on ebay at the moment with this part number: MHK100620G
What is the correct one to go for? I believe that inferior copies are available but they don't last too long.
Thanks in advance.
Post #185148 14th Nov 2012 10:51pm
wslr
These are Genuine Part. The same without the Genuine Part barcodes on the bottom of them.
Post #185160 14th Nov 2012 11:10pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
Personally, I wouldn't buy a MAF off eBay, unless it was an eBay store of a reputable LR parts supplier. There isn't much differential in buying fom local LR parts or if you need to buy online use one of the main LR parts suppliers.
For the MAF it's just not worth the hassle of risking getting an inferior copy.
Steve
Post #187119 22nd Nov 2012 9:39am
mk1collector
Did you read the question? The op asked if it was a genuine part because Landrover don't make all their own parts. If Siemens make the maf for Landrover and you buy from them you don't get the Landrover markup
Post #187131 22nd Nov 2012 11:18am
Martin
Site Admin
There's still a risk of buying a fake Siemens VDO part, particularly on eBay.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #187133 22nd Nov 2012 11:29am
TD5_90
Thanks for the replies.
As I suspected re "OEM" etc. I shall proceed with caution . . .
Thanks again
Post #187139 22nd Nov 2012 11:46am
vulcanfreak
2006 Defender 90 Td5 Silver LE Zambezi Silver
please be aware a lot of sellers are listing parts as OE/OEM, to me and most people that means Original Epuipment but the new trend is for it to mean Or Equivalent Neutral
Post #187207 22nd Nov 2012 5:36pm
SteveG
Yes and I thought it was a helpful bit of advice. Unfortunately there are too many Charlatans on eBay and a lot of time you can't go by picture or description. I've fallen fowl of this myself, buying what was described as genuine LR parts only to find they are cheap aftermarket spray painted parts.
Steve
Post #187232 22nd Nov 2012 6:30pm
