Home > Td5 > TD5 temperature gauge fluctuating
Page 2 of 5 <12345>
excossack
Best I can do is a scanned image or two
Item 32 on the RHS middle
Item 32 on the LHS middle
 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #184962 14th Nov 2012 12:11pm
landyman37
Hi I cannot make them out on my ipad could you take a pick with your phone and email it me philgreen37@hotmail.com
Post #184970 14th Nov 2012 12:21pm
excossack
Sent. Hopefully you can read the picture ok. 1999 Defender TD5 110
Regards
John M0VAZ
Post #184983 14th Nov 2012 1:29pm
Martin
Site Admin
Remember that the gauge control is via the ECU, not direct from the sensor.
Looks to me to be an intermittent connection between ECU and gauge, but check the earth and 12V supplies to the gauge too (might be a loose connector).
This might help: https://www.defender2.net/gallery/albums/u...rected.pdf  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #184986 14th Nov 2012 1:48pm
stuckinmud
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Bonatti Grey
had a very similar problem on a previous td5 defender
it would run for 35 miles ish temp gauge went mad followed by engine cut out then had to wait 5 min before it would restart would do anotherr 30 mls or so then same again.
somewhere on the internet similar problems were reported to be caused by fuel pump relay (one of the two yellow relays approx 35mm square by 70mm high located under drivers seat)
opening the relay carefully with two knives showed a lot of burning in there. new relay fitted and the problem went away but the temp gauge would occasionally not read.
i am not sure whether the fuel pump relay going bad causes the temp gauge fluctuation or whether a poor earth to the under seat area causes both the relay and gauge problems.
as mentioned in this thread the gauge is not connected to the sensor directly but communicates via the ecu which shares the same underseat location as the fuel pump relay and therefore probably the same earth.
just running a new earth directly from the battery to the underseat box did not solve my problems; they didnt go away until i replaced the fuel pump relay but it may have been a poor earth that caused the relay failure.
Post #206149 28th Jan 2013 12:59am
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Mine went mad because it had an airlock. My first thought was to get out the wiring diagrams
Post #206164 28th Jan 2013 8:21am
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
Laurie wrote:
Make sure your radiator(s) is clean.
TD5 Rads can only just cope.
Mine suffered exactly this fault, but I had a rad waiting to go in. When I hosed mine out, I got about 3 gallons of sand out of the fins. Well worth a look.
Post #206168 28th Jan 2013 8:25am
excossack
On a trip up the M6 the needle flickered a little and then dropped back to the start of the gauge and stays there until I stop the engine and restart. Then for a bit it works and the drops back to the start as if the engine is off. 1999 Defender TD5 110
Regards
John M0VAZ
Post #206264 28th Jan 2013 4:50pm
993porky
United Kingdom 2002 Defender 90 Td5 HT Baltic Blue
I bet it'll be your radiator,I had same prob for two years frustrating,anyway my rad sprung a leak so went to local rad specialist and I bought a new one the old one must have been 4 times heavier than new one so they pressure tested it and it turned out to be partially blocked,anyway since new rad fitted never once had a bouncing temp guage, I'm not saying you need a new rad maybe just just disconnect it and flush it out
Post #206400 28th Jan 2013 10:28pm
joelyates18
Wales 2000 Defender 90 Td5 HT Chawton White
Just out of curiosity my temp gauge always stays just below the halfway mark.. It's not a problem the thing drives like a dream I was just wondering if anyone else has noticed this or if its just one of those defender mysteries.
Post #206403 28th Jan 2013 10:32pm
Laurie
The guage is analog up to the 'just under halfway' point, after which it becomes digital.
It will remain at the 'just under halfway' point until the temperature reaches 105°, above which it will go directly into the red and put the engine into 'limp' mode.
Post #206408 28th Jan 2013 10:39pm
joelyates18
Ahh interesting thanks for the quick reply Thumbs Up
Post #206421 28th Jan 2013 10:52pm
excossack
Thansk for the PDF link Martin. It is different to that of the Haynes manual as its doesn't mention the other temp sensor, just the one in the hose on the cylinder head.
Is there a list of the earth header locations?
If I am reading the diagram correctly then the Speedometer (J101), Coolant temp guage (J103), and Fuel Gauge (J104) share an earth and also the earth for the fuel sender taps off the same wires? 1999 Defender TD5 110
Regards
John M0VAZ
Post #206864 30th Jan 2013 6:26pm
excossack
What does conversion from analog to Digital ? The ECU or some other sensor? 1999 Defender TD5 110
Regards
John M0VAZ
Post #206865 30th Jan 2013 6:27pm
Laurie
Presumably the whole gauge is digitally fed from the ECU. I used the terms to describe the action.
The thing is that the ECU does not progressively move the gauge between the mid point and the max point, it moves it in one instant movement. At 100° up to 104.9° it remains at the mid point, at 105° it goes straight to the 'red'. On some occasions the gauge will go to zero instead.
Post #206869 30th Jan 2013 6:36pm
Page 2 of 5 <12345>
