Home > Technical > steering boss
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
steering boss
I know this may seem like a dumb question, but why are the steering boss' fitted to the small steering wheels (Mine's a momo) so "deep", seeing as I am a bit of a short arse and I have the seat a little forward the steering wheel is very close to my ample belly... yeah yeah, I know, get rid of the belly, easier said than done, so back to the question, the steering wheel is a lot closer because of the boss, so why are they so deep? or high? can I modify a boss to put the wheel back? I'm sure there is a perfectly reasonable explanation Whistle Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #184229 12th Nov 2012 2:24am
ZeDefender
Extended/raised seat rails worked for me in several ways - I believe I have similar physical "attributes" to you Whistle
Combine with raising the cubby (extra storage) and driving is almost comfortable Wink
p.s. I also have a deep boss but don't know why... Tell someone you love them today because life is short.
Post #184234 12th Nov 2012 7:46am
I made a boss for my momo wheel, as the supplied one was about 4" deep!
I took an old steering wheel, cut the middle splined piece out, then turned it on the lathe at work to make it "round" again, then cut a piece of 4mm plate, turned that so it was round, and cut a hole in the middle of it, welded the piece from the steering wheel into it, drilled and tapped the holes for the screws to hold the wheel on. job done.
I've got some pics somewhere I'll post up.
Post #184243 12th Nov 2012 8:59am
taffrican
D-Jim, that would be appreciated, cheers Thumbs Up Optimists say the glass is half full..
Post #184271 12th Nov 2012 11:21am
yorky
England 2007 Defender 90 Puma 2.4 SW Java Black
Ha - raising the cubby box, why didnt I think of that! Have put the seat risers on and fitted my Momo Tuner wheel with quick release boss and all is well except my left elbow is 5cm too high to rest easy on the top of the cubby. Been thinking of a extra padded cubby lid or have a surgical adaptation to my elbow! Neither would be a good idea - but raising the Cubby box is so flippin obvious - thanks Ze, its on my mod list! 90 XS
Volvo V70
Post #184276 12th Nov 2012 11:38am
Killer90
Site Sponsor
get the padded top type cubby they look great and are comfy Thumbs Up Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #184378 12th Nov 2012 7:13pm
taffrican
Oi!! you two, b*gger off and get yer own thread!! Whistle
Rolling with laughter Rolling with laughter Rolling with laughter Optimists say the glass is half full..
Post #184390 12th Nov 2012 7:32pm
Killer90
Site Sponsor
Rolling with laughter Rolling with laughter Off Topic there we go Thumbs Up CSK Automotive
Post #184414 12th Nov 2012 8:13pm
K9F
Re: steering boss
Think you've got problems.....I took advantage of the fine weather this weekend and took the boat out....Think I ought to take up a different hobby.....or get a bigger boat perhaps....
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #184418 12th Nov 2012 8:21pm
taffrican
Re: steering boss
Shocked Shocked I think I just found my Doppelgänger Shocked Shocked Optimists say the glass is half full..
Post #184419 12th Nov 2012 8:25pm
ZeDefender
Rolling with laughter Bow down
How can you see what you're welding? Tell someone you love them today because life is short.
Post #184420 12th Nov 2012 8:26pm
Killer90
Site Sponsor
haha thread wrecker Rolling with laughter Thumbs Up CSK Automotive
Post #184421 12th Nov 2012 8:28pm
OK, back in topic....
Very picture heavy this one:
OK, here's how I made my steering wheel boss. The reason for it was the one I bought (as most seem to be) was HUGE! It brought the wheel a good 4 inches or to towards me, which looked ugly and made for a naff driving position.
The bought boss:
So I got hold of an old knackered 4 spoke wheel with the correct splines, and set about cutting the middle piece out of it with an angle grinder.
Not pretty, but quick!
I then stuck it in the lathe at work, and turned it into a proper round shape.
Then I took a piece of thick (think it was 6mm or so) plate, and cut that into a round shape on the lathe, and also cut a hole through the centre of it to take the turned-down boss from the old wheel:
Placing this turned flat plate onto the new steering wheel, I could mark the position of the screw holes, drill them and tap them out:
So the middle splined boss needed to be welded to the plate:
I also welded a thin (1mm or so) piece of flat steel to make a skirt, just to hide the backside of the boss and make it look a bit neater.
Some black paint, and job done!
And finally, in place;
Post #184428 12th Nov 2012 8:34pm
Killer90
Site Sponsor
Thumbs Up Thumbs Up very clever idea Very Happy CSK Automotive
Post #184436 12th Nov 2012 8:44pm
taffrican
Thanks D-Jim, a cracking job done there, that's definitely my next job Thumbs Up
thanks for going to the trouble of uploading pics, much appreciated Bow down Optimists say the glass is half full..
Post #184437 12th Nov 2012 8:44pm
